TTD help
RadioChief55
Sorry if this is in the wrong spot. I been going through posts looking to figure out my TTD issues.
I have it set up and it did detect a tone a generated, but I didn't receive an email with it. After a while it locks up and the only way I can get it to work again is to go into task manager and close it and then reopen and it will work for a little bit. I'm using it on a windows 10 desktop I use to provide a few feeds. I will post a bunch of pictures of settings, messages and the debug. I do get a error in the debug some times, but not always. Thanks
aaknitt
1) For the not sending, you should have the actual email address in the "Email From" field. You'll likely also have to use an app-specific password with gmail (see some of the other threads on here for more info).
2) The locking up appears to be due to TTD having trouble accessing the sound card. Is the PC set to go to standby or sleep? That's a common source of that kind of problem.
RadioChief55
The PC doesn't go on stand by or sleep. I have it running 3 Broadcastify feeds and 2 Zello feeds. I got an error before that said wrong password for email. I double checked it a few times and nothing.
RadioChief55
This is an error message I get
RadioChief55
Would it matter that I'm running 73f? I see 37I is available on their website? Thanks
DC31
Massachusetts
3. in your Long Tone configuration, there is a ToneLength of 1230. This is extremely excessive. Maximum should be about 8.
4. in the last two debug window snapshots, there are strings of 360.0 hz samples. This is likely carrier noise that could be eliminated by moving the squelch slider to the right a bit.
i am not sure that either of these will correct your issue, just items that I noticed. Yes, gmail passwords will drive you crazy.
RadioChief55
Thank you for the help. It was the password not working because as on May 31 Gmail changed security to two-factor authentication: and you need to set it up and use the 16 digit app security code you get from the security section of your Gmail account once you set up two-factor authentication: DC31 has it posted above.
RadioChief55
So I'm still getting this
OSError : [Errno -9999] Unanticipated host error
The program will run for a little bit then just freeze up and on the debug it gives me the above code and below is a screen shot of the error. I'm running Windows 10, I can only find this error in ttd with raspberry pi, not windows 10.
