Two Tone Detect
coyote4500
Edison, New Jersey
Been using Two Tone Detect ver69A for over year. Now ATT&T an Tmobil numbers do not work. Tried updating to Ver 70. Tmobil works BUT not ATT&T? Whats my problem.
Coyote
DC31
Massachusetts
Do text alerts without the audio attachment go through? If they do, v71 includes an audio hosting option where you text out only a link to the file rather than the whole file as an attachment. No guarantees, but that might work.
coyote4500
Edison, New Jersey
Ok tried loading Ver71. went in Ok. After sending 1 page out I get a pop up that says "Failed to excute script Two Tone Detect 71c". Now what ???
coyote4500
Edison, New Jersey
Installed Ver 70. Had the same problems. With little reading the log files came up with audio hosting and add hyper link boxes were checked. Unchecked them seem to be working fine. Thanks for the help. I have 100 happy campers now.
Coyote
NvFire
I switched computer location that i was running two tone with so i have easier access to it, first it wouldnt allow the computer to send emails as gmail blocked it. so i fixed that issue and had to change the password in the two tone config, after doing this now the program will not load. it will go through the motions as its going to load then crashes. i checked both config and tone files and both appear to be fine. any idea?
also tried finding the program download to try reinstalling but cant find any downloads or zip files anywhere...
NvFire
Open the logfile for that date and look for error messages
Traceback (most recent call last):
File "<string>", line 116, in <module>
File "C:\Users\Andy\Google Drive\Python\build\pyi.win32\TwoToneDetect65d\outPYZ1.pyz/base64", line 76, in b64decode
TypeError: Incorrect padding
Succesfully retrieved local tone info
Tone1
[618.0, 618.0, 618.0, 725.0, 725.0, 725.0]
File "<string>", line 782, in <module>
NameError: global name 'audio_channel' is not defined
Tone1
DC31
Massachusetts
Open your config.cfg file with a text editor. There shoukd be an audio_channel parameter. It should be audio_channel=mono
NvFire
Nothing will open two tones, editor or debug they’ll all start to open then crash. The config file is set to mono and I even did a side by side comparison of the sample config and sample tone files just to make sure everything was ok. They both match each other.
I wana do a new install and start from scratch but the download or zip is no where to be found
