TYT *default//OEM* programming software
You may have seen my other post regarding my new TYT TH-8600 and using RT Systems to program it. That's a separate conversation and I appreciate everyone's replies.
This conversation has to do with TYT's programming software they package with their radios. I've had no issues programming about 25 simplex channels and the NOAA weather channels. Good!
The issue I'm having is programming my local UHF repeaters. The OEM software doesn't seems to have enough input fields to program the tones, etc. And, in order to program tones, I have to select DTMS, 2Tone, or 5Tone. Where is there no CTCSS or PL option? Here are some of the repeaters I'm looking to program into channels 100+.
Frequency Offset Tone Up / Down Location County Call Use Operational status
442.0000 +5 MHz 82.5 Clinton, Holly Mountain Airpark Van Buren N5YU OPEN ON-AIR
442.0500 +5 MHz 110.9 Fayetteville Washington WC5AR OPEN ON-AIR
442.1250 +5 MHz 118.8 Lamar, Red Oak Rd Johnson KE5SQC OPEN Unknown status
442.1750 +5 MHz 82.5 White Hall Jefferson KJ5PE OPEN ON-AIR
442.2000 +5 MHz 97.4 / 97.4 Springdale, Beaver Lake Point 12 Benton N5KWL OPEN ON-AIR
chief21
Summer - Western NC; Winter - Tampa Bay FL
I'm not familiar with the TYT OEM software, but in most other CPS apps the CTCSS settings (access codes) are usually not in the same area with DTMF, 2-tone or 5-tone options (signaling codes). Try to look in other areas of the application and be aware that the chinese often label functions differently than you might expect.
chief21
After reviewing the user manual, it appears as though TYT might label CTCSS/PL as CTC. If you can't find how to set the tone in the software, you can always set it on the radio directly for each memory channel (after you load the frequencies and other parameters).
