TYT MD-2017 blank screen
khigh65
Hi all.
Got my TYT MD-2017 last week and been enjoying it so far - been building a codeplug everything going well.
Except one time I wrote to radio and the screen has been blank ever since.
I've tried rewriting an older version of the data to the radio. I've tired upgrading the firmware.
Everything works, apparently - I just can't see it - it reads and writes in software and the firmware updater, and I can even use it to talk if I know what channel I'm on. I just can't see anything.
I've found one other user reporting this problem, but no solution.
Any ideas? Could I have a dud?
Thanks for looking.
FKimble
Newnan, GA
Sounds like either the display has died or a cable going to the display is loose, not making contact. Send it back or call for warranty support. If paid with c.c. you may have some recourse to recoup your money.
Frank KK4YTM
khigh65
Thanks for responding. The timing just seemed weird that it did it when I wrote to it. I was deathly afraid I'd done something wrong.
Fortunately it's only a week old and I bought it at HRO, so I'm fine there. My only question is whether to get a replacement or a refund.
If it's just me and one other guy, maybe the problem isn't widespread.
khigh65
I took it back to HRO. they grumbled a bit, but exchanged it.
Funny thing is, after riding around in the car, about 4 hours of which was hot sun, it had a display when I brought it in, but both channels read "Disconnected". I told him the behavior was to sporadic to let it go outside the return window, so they gave me another one.
ExHamOp
Not the MD2017, but I have had two TYT MD380 VHF radios with the same problem. Blank white displays. Both happened while the radios were in use, actually in QSO. I flashed the newest firmware from TYT but that didn't help. Nothing has helped. They operate normally but have no display. I gave up and purchased a radio from a different manufacturer.
teufler
ST PETERS, MISSOURI
might check, was the radio flashed with the right firmware. Did you use a gps version on a non gps radio? I did by mistake=, and after somebody on RR suggested I double check, that was it. I have a 390 with gps and by force of habit, on the 2017, I chose gps when I did not have the gps version. just and idea to try.
dwgelle
Meeker Co.- MN
Just this morning I powered on my 2017 and the screen is blank/white. Worked fine yesterday. Will have to contact where I got it from.
eaf1956
Evansville, IN
I had the same issue with a TYT MD 9600, so far my MD2017 is fine.
