Tytera TYT MD UV-380 programming
pgrundle
I am very new to DMR and have a UV-380. I have programmed the radio with the software with a local DMR repeater. The radio indicates signal being received but I cannot hear anything. In addition I tried a test with Parrot, 9990, and no such luck.
Any advice?
Patrick
VE7PJG'
RichardKramer
Reading, PA
Any advice?
Patrick
VE7PJG'
Patrick, I just started programming mine this week. When an analog freq is programmed, the audio comes through ok; when a DMR freq is programmed, I have to hold the button in above the ptt button until a little blue speaker icon shows in the display; then the audio comes through. Each time the radio is turned off or after changing channels on a DMR system, you have to push that button in until the little blue speaker icon shows in the display. I'm trying to find a way around this, no luck so far. The Reading Hospital PD/Security uses a DMR trunk system here in Berks County, PA; and every time I turn the radio on, I have to get that blue speaker icon on or no audio comes through. Hope this helps get your audio through.
Rich - N3VMY
pgrundle
Thank you for your reply. I have the speaker icon and have pressed the PTT to access the talkgroup. Radio shows signal received and LED indicates audio with green light but I don't hear anything.
Very odd and could use some advice.
hill
Middle River, MD
You need to make sure you have a group assigned to the DMR channels. With many talkgroups on each repeater frequency more than likely you are receive a group not programmed in the radio.
pgrundle
Double checked the setup and everything looks right but still no audio. 2m analog repeaters are not a problem at all and either is simplex.
Quite stumped.
RichardKramer
Reading, PA
Quite stumped.
My blue spkr icon is on the left side of the H in the upper display wihtout an x on the side. In your menu go to Buttons definitions and for button 1 short push, scroll to monitor and put that in . Then reprogram the radio and give the top button a short push and see if that doesn't change the blue speaker icon. I couldn't get a menu change to get the blue speaker icon to the right side of the H with an x thru it like on your pictures. I also put scan on/off in the bottom button short push; upper button long push is power select; bottom button long push is Zone +. Try those settings and see what happens with the audio.
Rich
RichardKramer
Reading, PA
Rich
I should've mentioned you need to make the changes on the computer program menu, not the radio menu itself.
Rich
