Tytera MD-UV390 encryption issue
turdish
Hello, I've recently boutght Tyt MD-UV390 10 watts version with AES256 encryption. It has a "AES256" sticker along with "Plus" in battery chamber, so I guess it's Plus version. AES256 doesn't work, neither do ARC4 and AES128. Enhanced and basic did their job well. Creating keys then changing them don't work.Everyone can hear the voice as if it were not encrypted. CPS v02.34. When trying to download "privacy", it downloads it correctly - name and type of enc is correct, although keys are blurred and protected. Where is the problem? Thanks for any advice.
Disclaimer: in my country, ham radio can use enc.
3 Questions;
1)I under channel programming, did you select enc type AES and key ID assignment for the specific channel?
2) what version of firmware are you running on HT? I was able to get it working on FW ver s119.33 (link found on a forum link here somewhere).
3) when you initially load encryption in cps it is in the clear. I advise saving it off to a .Dec file on your PC for other radio programming If needed. For some reason when reading the enc from radio it obfuscates the keys (security feature, I guess). Once you read from radio you can save to a .dec file and reload on other radios.
The trick to getting AES universally working with other radio brands (Moto, Anytone, radioddity); you have to ensure that the Key Alias is named the same on all radios. For example; by default TYT naming convention for keys is numerical name (1,2,3, etc). Radioddity uses name conventions are hard coded to "AES1", "AES2". So to get them both using the same key, the TYT keys need to be renamed to "AES1" "AES2".
Hope that helps a bit. Will try and find fw and cps links and post them for you.
naffMaster
1. I select universal enc and key name/ID/whatever.
2. S219.043, as I have written.
3. Is this necessary to have the communication between Radioddity and TYT by naming the keys exactly the same? In Tyteras 390 Plus it doesn't matter. I had checked it already.
I have the CPS for my FW. Thanks.
turdish
Hey sorry for late response. Yeah for me the key had to have the same name. I'm not a DMR engineer, but I think the key name may be incorporated with the key checksum in the initialization frame/header when Txing...maybe.
WFRP399
3 Questions;
Does anyone know what Motorola/Vertex use for key aliases with ADP?
I have been goofing around with a UV-390 Plus and an EVX-534 trying to get the ARC4 to work together but they won't.
WFRP399
Here are the Settings in the CPS for the UV390
Here the settings in the CPS for the Vertex EVX-534
I can't the EVX and the UV390 to talk to one another. I tried naming the Alias "1" on both radios and also tried "PRVY - 1" on both radios. The squelch opens up, the radio tags appear but the audio is scrambled. Two UV390s will however work together just fine using the above settings.
Any idea of the Enhanced Privacy on the Vertex is something other than ARC4/RC4?
doriboni
Do you have the possibility to record a.wav file with an RTL-SDR of your ARC4-UV390 and your ARC4-VERTEX?
irudzko
Hello! It seems like you're experiencing issues with encryption on your TYT MD-UV390 Plus. The problem might be related to the CPS version you're using. CPS has been updated, and the latest version is v02.41. Updating to this version could resolve the encryption issues you're facing.
You can find the updated CPS v02.41 and related firmware at TYT MD-UV390 Plus CPS and Firmware.
Back up your current settings before updating, and carefully follow the instructions provided to ensure a smooth update process. I hope this helps!
EA4HUO
Louie7 is right.
This is the firmware, that TYT support sent me.
Thank you so much naffMaster. You saved my day. I bought a TYT MD-UV390 10W AES with GPS a month ago and I was getting to know the radio, the CPS and DMR at the same time. I decided to experiment (a bit recklessly as I see it now) and try another firmware... getting a 100$ brick. I didn't take into account that
1. these radios were so picky about the FW, depending on the specific HW: 5-10W, GPS, AES support...
2. the FW loader was not going to perform any minimal compatibility check
3. the worst of all, I never thought that getting the STOCK FW would be so difficult!
After much search in panic I found version MD-UV380-10W-AES256(REC)-D219.43.bin. With this, the radio came back to life, much to my relief, but with a serious proble: the backlight didn't work. Only when pressing the PTT. All worked apparently fine, but you needed a bright light to read the screen. No way to use.
Then I found somewhere another version, that (at last!) worked fine: MD-UV390-AES(GPS-REC)-S119.38.bin. But checking a previous codeplug I saw that it was a version older than the one the radio came with.
Then I found somewhere another version, that (at last!) worked fine: MD-UV390-AES(GPS-REC)-S119.38.bin. But checking a previous codeplug I saw that it was a version older than the one the radio came with. The version you posted i exactly the one I needed and the radio works fine once again.
Thank you so much!!
