Tytera announces new mobile DMR radio.
eaf1956
Evansville, IN
OK TYT released updated firmware and Programming software and now all is GOOD on the MD 9600.
A lil note: While the new software appears to import MD2017 codeplugs, when I wrote mine to the 9600, the radio is frozen. It won't transmit and the controls are frozen. I went back to one of my original test codeplugs (less information) and all works fine. That codeplug was coded using the 9600 software.
IW2BSF
sorry for this mobile TYT MD-9600
1) the CPS and SW to program is the same of the MD-2017 or not ?
2) is possible to put and see the all WW database of the ham-radio (call, name etc... ) ?
best 73
eaf1956
Evansville, IN
best 73
1) No, not the same
2) not at the moment, I don't think the screen has the space anyway
IW2BSF
thanks.... you say not space (is not little.....) for see on the display the Callsing , and other info of
the ham-radio in rx , NOT GOOD this by TYT !
73
eaf1956
Evansville, IN
73
You can see the callsign IF you have that person in your contact list!
eaf1956
Evansville, IN
And today 8.31.2017 TYT released another firmware update for the MD9600 radio. This is version 3.29 replacing the 3.28 version which was released to fix the radios that were shipped not working.
Drumbum
Lynchburg Va
All else fails make it work after the customer gets it, I'm still keeping my eye on this radio until all the bugs are worked out and they're readily available I really want this mobile
Sent from my VS995 using Tapatalk
eaf1956
Evansville, IN
The old programming software did NOT work, the old firmware the radio shipped with did NOT work. Since then they came out with new programming software (went from 1.12 to 1.18) and new firmware 3.28 was the first one that worked and now 3.29 is out. Works as I updated to 3.29 this morning. Waiting for the 100K contacts thing if they can even do that on the 9600 with the display being so small.
IW2BSF
1) the NEW fw solved the problem is not programmed in vhf ?
2) after the add od the call in the list of the radio.... there is NOT the
possibility to add like the MD380tools or ToolZ to see all the ha-radio calls of the world ?
Yapper
NC
Does the dual band TYT MD-9600 have simultaneous receive? What about cross band repeat?
Yapper
NC
That's too bad. I can't fit it in the car and I need crossband repeat around the house. TYT is coming out with some nice stuff but they need to add a Ham or two to their engineering and design staff.
alcahuete
Antelope Acres, California
The 9800 has that. The 9600 does not. If you can give up DMR, go with the 9800.
stantorres
Auburn Hills, MI
Powering on
If an MD9600 was powered on when 12 volts was disconnected, when 12 volts is applied, does it power back on automatically?
In other words, when I start the car I want it to power on without having to press the power button manually each time.
