UAW radio programming
RyCoy
Montrose, Pa
I've got a couple of UAW radios that.com trying to program. The tone code I was given for two of the frequencies (as programmed in a number of Kenwoods) is D251. The drop down list in the uaw programming software has D251N and D251I. Which one the two would be right?
Ryan
Avery93
AL
Will probably be D251N, or Normal polarity. I have never come across a radio that required Inverted polarity, but they are out there; so If normal doesn't work, use D251I.
Avery93
AL
Would this be the same for transmit and receive?
Yes, use the same code for both transmit and receive, whether it is inverted or normal polarity. Like I said, normal polarity will more than likely be correct; but the only way to be sure is to just try it and see.
yuiop
Oroville, CA
Scan and chan lockout
Does anyone know how the UAW programing software handles the scan add/delete, and the busy channel lockout? I can't figure it out and there is no documentation in the help menu.
