UCAN Multi-Site/Roaming Setup Theory
bchris
Salem, Utah
I need some help from you folks in the North and West to further refine my UCAN programming. This post might also be helpful for some people to get more set up ideas. For those who are interested, I have listed below some background info on how my scanners are set up at the moment.
For each site I entered the Control Channels and the backup CCs. I use the ‘CC mode only’ setting, so I did not enter any voice channel frequencies. A few sites are busy enough to justify being set up as their own system in my scanner (using Closed/Scan mode) while the rest I can just put all together in one system, run it in Open/Search mode and listen to all traffic from that site whenever I am close enough to receive it. For this discussion I am talking about Uniden models BR330T and BCT15. Later on I plan to adapt it to my GRE PSR500.
To increase scan speed and minimize entering the same TG’s many times in my scanner, I would prefer to combine more than 1 site together into the same system, as long as I do not exceed the 250 TG limit of my scanner. An example of when this works especially well is for my system named East&West. It contains all local talkgroups for the Tooele & Heber & Park City areas, plus all Statewide and Corrections, and the total is still under 250.
When my scanner cannot detect any control channel from a given site, it does not use any time looking for TG’s from that site. For example, while in Tooele I don’t waste a full second every scan cycle looking for TG’s on the Park City site, even though neither site is locked out. (It might still use a fraction of a second per site looking for the control signal.) This works even better on my BCT15 w/ the GPS, because the distant sites are locked out and then automatically unlocked just before the site is in range.
SIMULCAST AND/OR VERY BUSY SITES:
Some of the UCAN sites or areas are busy enough to warrant their own system in my scanner. These busy sites would overwhelm the other, less active sites if they were all left in the same system. For these busy systems I only want to hear certain select talkgroups, not all traffic on that system. Therefore I will use ‘closed/scan mode’ instead of ‘open/search mode’. For example, I don’t care to listen to Layton’s busy water department on it’s already busy site, but an occasional comment from a small town’s water dept on a not-busy IR site is fine. The areas that I have right now set up as their own system are Salt Lake County, Davis/Weber & North, Utah County & South, and East & West. All other sites are grouped together as ‘IR sites’.
SYSTEM NAME
PRIMARY SITES
SECONDARY SITES
TALKGROUPS INCLUDED
SL County
01,02,03,04,11,18
06,09,10,25,36
Statewide, SL County, SL Cities, Corrections
Davis & North
01,02,03,11,53
06,07,08,09,10,14,22,39,40,42
Statewide, Weber, Davis, Cache
UT County & South
03,04,11,18
21,24
Statewide, UT County & South, Provo&Orem, UDOT
East & West
11,24,30,32
06,07,08,09,21,22,25,31,35,36
Statewide, Tooele & West, Park City & East, UDOT, Corrections
IR Sites
Specifically Excluded: 01,02,03,04,11,18
All Others
Most active 250 based on statistics from multiple sites received from my location.
ALL OTHER UCAN TRUNKING SITES:
BCT15 ONLY:
Since my BCT15 uses a GPS to lock and unlock sites automatically as I travel, I also entered the center and radius of each coverage area. To define the coverage areas, I entered every site’s LAT/LON and radius into MapSource, then adjusted them until they looked to me like they matched reality. (MapSource will draw a circle on the map according to my settings.) The center of the coverage area is usually not exactly where the tower is located, and my chosen radius depends on Tx power output, terrain, and how far away the site’s neighbors are. I wanted to use Google Maps instead of MapSource, but I could not figure out how to make it work like I wanted it to. Any help here would be appreciated. For sites near the busy metro areas I use a smaller radius to avoid having too many busy systems enabled at the same time, and for the outlying sites I use a larger radius than I actually expect to receive.
BR330 ONLY:
This scanner will stop on the first control channel it finds, ignoring all others in that system until it loses the signal, at which time it will look for another. I divided the IR sites into 4 groups, and created a separate IR system for each group. Rather than putting all sites for a given AREA into the same group, I did quite the opposite. I analyzed the location of each site relative to each other, and attempted to arrange them such that only 1 site from each group could possibly be detected from any given location in Utah. Since each of the 4 systems are always trying to find a signal from one of the sites in it’s own list, I will be monitoring up to 4 separate IR sites at a time, no matter my location.
Here is an example. Lets say I am driving through the Heber area. The area’s simulcast system is not scanned as an IR site, so forget about it for now. I am still surrounded by the sites Lewis Peak, Clayton Peak, Strawberry Peak, and Daniels Canyon. If these were all in the same system, my scanner would choose only 1 site at a time, and would ignore the others until it lost the first signal. On the other hand, since these sites are each in a separate system, my scanner will choose 1 site from each system, and I will hear any and all traffic from each of these sites. Note that South Mtn, Logan Peak, and Gunnison could all share the same system along with any site near Heber, because there is no chance of receiving any 2 of them at the same time. A while back when I tried to set up each IR site as a separate system, it took too long to scan and since each system uses it’s own list of talkgroups I ran out of memory way, way too soon.
COMMON TO BOTH SCANNERS:
Even though I will run this system in ‘open’ mode (by this I mean ‘search’ mode, as opposed to ‘scan’), I want the scanner to display the name of the Talkgroup, not just the TGID#. My scanner capacity is 250 talkgroups per system, so I used Unitrunker to monitor all the systems I can receive from my house (one at a time) to determine the 250 talkgroups I am most likely to hear. Now if the active talkgroup is one of the 250 it displays the name, if not it just displays the ID #. 95% of the time I see the name.
The decision to exclude 01,02,03, & 04 from the IR sites is pretty obvious. 11 & 18 were excluded because I can RX them from my home so I knew they both carry a high volume and a wide variety of traffic. Surely there are other sites in the northern areas that are busy as well, but I need help from someone in those areas to identify them. Specifically I need to know which sites they are and what agencies use them on a regular basis. Note that 11 & 18 are not set up as their own system, but they are used as an alternate site within other systems. Also note that they are specifically excluded from being monitored as an IR site while I am traveling.
Thanks Everyone
-BC
bchris
Salem, Utah
Correction to table format
I was in a hurry to be somewhere when I made the previous post and did not preview it.
When I got home and saw the table formatting was wrong, my option to edit was gone.
Here is the table in a slighly more readable format.
SYSTEM NAME....PRIMARY SITES....SECONDARY SITES....TALKGROUPS INCLUDED
SL County............01,02,03,04,11,18.......06,09,10,25,36..........Statewide, SL County,
............................................................................................SL Cities, Corrections
Davis & North.........01,02,03,11,53..........06,07,08,09,10,.........Statewide, Weber,
............................................................14,22,39,40,42..........Davis, Cache
UT County & South.....03,04,11,18................21,24.................Statewide, UT County &
...........................................................................................South, Provo&Orem, UDOT
East & West............11,24,30,32...........06,07,08,09,21,.........Statewide, Tooele & West,
..........................................................22,25,31,35,36...........Park City & East,
..........................................................................................UDOT, Corrections
IR Sites...........Specifically Excluded: ......All Others...............Most active 250 based on
........................01,02,03,04,11,18........................................statistics from multiple sites
..........................................................................................received from my location.
kd7rto
Bountiful, Ut
You put an awful lot on your plate. Here's how my commute goes:
Leave home in Bountiful monitoring UCAN cell 2, with enabled talkgroups:
Regionals, Techs, Airmed, LZ, Davis County, Bountiful, S. Davis Metro Fire, and all related tac channels. Layton and Clearfield locked out.
Crossing the line into Salt Lake County I deselect cell 2 and select cell 3. Enabled talkgroups are: Regionals, Techs, Airmed, LZ, and all UHP channels used in the valley. While on the freeway, I keep Unified Fire, city PD’s and the Sheriff locked out.
Exiting the freeway I deselect Ucan cell 3 and select AC33, with Salt Lake PD and fire selected, airport and everything else deselected.
If something goes down in the southern part of the valley, I’m going to miss it, but I would rather chance that than have my scanner locked on a 10-60 in West Jordan, while Salt Lake is sending units to a hot incident a block away from me.
N7YUO
Kearns, UT
In my PSR500 I have a TSYS or "system" Labeled I-80.
I have Wendover Peak, Delle, S Mountain, Nelson, Lewis, and some others along I-80 that I can't remember. When this TSYS is enabled, Scanlist 8 scans all police, fire, SAR for Summit & Tooele counties. Only when I am locked onto Nelson do I hear both counties.
Of course I do not include SL Simul with the I-80 TSYS for obvious reasons.
As I travel toward Wendover or Evanston, the scanner will acquire a new site as soon as it loses the CC of the one it is locked onto.
OK, this is surely going to confuse some "Dummies" (If you're offended, look at my avitar)
Even though Wendover Peak, Delle, S Mtn, Nelson Peak, etc all belong to the 7202 UCAN system,
they are PROGRAMMED as if they were a separate system. Program in the CCs and Alt CCs for the various IR sites, and program in the TGRPs you favor. Omit the junk like UDOT, Animal, Water, etc.
bchris
Salem, Utah
Northern Sights (do they glow different colors at night?)
Thanks kd7rto and N7YUO for your previous comments.
For each busy Simulcast area it would make sense to have a separate, standalone site available as a backup that covers the same general area and carries the same traffic.
For Utah County that seems to be West Mountain. For Wasatch it seems to be Lewis Peak in the north and Clayton Peak in the south. It looks like Logan Peak will remain intact as a backup for Cache County. Do you Cachians agree?
Even though Nelson is not Simulcast, it is so busy and carries such a wide variety of traffic that I tend to think of it as a Simulcast, not a backup. Therefore maybe South Mtn or Delle could be thought of as the 'redundant' site(s) for Tooele. Or do you Toolies consider one of these your primary site?
SL ADC, Point of Mtn, and Gunnison seem to serve ONLY the jail, the prison, and the prison, respectively. Does Davis County Landfill primarily serve only Hill AFB? Are there any other sites besides those 3 or 4 that are used primarily by a single agency?
Is Francis Peak busy and does it carry the same basic traffic as Davis Simulcast? Would anyone consider it to be a redundant or backup for Davis? What about Mount Ogden? What about Cal Mtn for Weber?
Some sites such as Strawberry and Teat have little to no traffic until there is an incident in the area. In other words, they are nobody's home or default system. Is this the case with Morgan, Echo, Hansel, Scotts Pk, Little Cottonwood, Delle, and maybe Mt Ogden?
Does Promontory fit any of the above profiles, or is it busy with everbody all the time like Nelson?
Thanks Guys - BC
wbloss
Human
Joplin MO
I'd agree to this one - DOn;t forget CAL Mountain - it backs up Northern Cache
Wally
Thanks Guys - BC
see above in BLUE
bchris
Salem, Utah
Davis County
Is anyone within range of Francis Peak or Davis Landfill?
When I drive through Davis County, should I listen to these sites in Open/Search mode or in Closed/Scan mode?
If there is not much traffic or they have an unusually wide variety of talkgroups, I would choose open mode and listen to all traffic on the sites. If they are very busy and have a known set of talkgroups I would choose closed mode, but then I need to know which talkgroups to scan - ie: if Davis Landfill carries only Hill AFB traffic, it would be a mistake to run in closed mode and scan public safety talkgroups - I wouldn't hear anything.
I know I can just listen to Davis Simulcast, and I will do so, but I am always looking for new, better, or more complete ways to scan. I guess I am just weird like that. I always have been and probably always will be. Surely I'm not the only one, am I?
Can anyone help?
--bc
ps: Thanks Wally.
