Really nice job. I should get my tape Monday. How hard was it to pull the foam up?
Thanks. It's not difficult at all if you take your time. I peeled up one corner and made sure I had the entire end peeled up before I started peeling down, slowly.
If you are referring to the foam block on the battery case, don't pull it up. Apply the copper foil over the foam block.
In my experience, placing the copper foil under the foam block has greatly improved reception.
Out of curiosity, this morning I placed a piece of copper foil tape over the foam... But it did not change anything, for better or worse.
Maybe it is related to the shielding properties of various tapes. As soon as i move my case even a 1/16th of an inch and the pressure from the foam on the batteries is gone. The noise comes back. Maybe it has to do with the condition of the foam. Mine is fairly squished as i change batteries up to three times a dayYou experience seems to be different than anyone else's.
Aluminum foil for cooking? If so we ruled out aluminum foil during the original tests. Aluminum shielding tape does work. Along with copper tape which is probably bestTried the fix with aluminum foil and had no improvement in the 450-470MHz range here in Center City Philadelphia.
Used the local stadiums as a test, which have a mix of DMR and analog signals for parking, security and staff. Also tried the airport. I could tell absolutely no difference. Without foil, the DMR signals from the stadiums come in perfectly fine, whereas the analog signals are a bit weak but readable.
The Custom Search method is kind of a joke here because of all the signals there are in downtown in the first place. You simply can't judge any improvement by the number of signals. It is like counting ripples in the Delaware River.
So I parked it on a weak NFM signal (sounds like some kind of school bus dispatch) on 452.250MHz and compared it with my BCD396XT to see if I could detect the difference that way. Both radios are using the stock antenna, both set to Squelch level 2.
My immediate observation is that the BCD436HP with or without foil is better at rejecting images from nearby strong signals, and thus the BCD396XT is actually worse at receiving this particular signal in this environment.
I heard no change to the BCD436HP with or without foil.
It doesn't seem like my crowded urban environment and testing confirms the observations here.
SN is 3726Z68001XXX.
.Please read all post before replying.. give us some valid details of what what and what.
Can you be more specfic. Cap type and value. Picture of wiring? Great findI put a capacitor across the battery + and - to filter the higher frequencies and that reduced it down to about what I was seeing with the foil.
No that poster is saying the exact opposite with what others are reporting, his is the only one reporting under the foam works best...
LOL!! :lol:I've always been exceptional; both in success and in relation to the rule.
Are the people with problems all using the stock rechargeable batteries that came with the scanner? From the videos I've seen it looks like it...
I recall someone saying that the issue reproduced with Alkaline batteries but has anyone else confirmed this..?
