My thoughts exactly. shielding this area, was one of the last areas I was looking to shield. Still not sure why the extra shielding under the batteries actually made things worse.
I suspect that the center cell is acting as a radiator of the noise - specifically toward the left side of the cell. That's where the noise sniffs the strongest. So, putting the shielding under that cell only serves to act as a better antenna. Putting it over the cell acts like an attenuator.
The closer the proximity to that cell, the better the reflective (or perhaps disruptive) properties.
At Kevin's recommendation, I put the foam pad back under the foil and WHOA.... What a change! I am now hearing things I wasn't hearing at all before without standing on my head and holding the radio up with my feet.....
Because the shielding is making better capacitive coupling with the center cell.
I'm leaning towards it's foil actually touching the battery that makes the difference.
The closer the shielding, the more capacitive coupling happening. An interesting test would be to try PRESSING IN on the battery cover of a shielded cover to see if that makes a difference.
So far all positive results except for jeffm77 not bad
He never has good luck receiving signals. :wink:
With the power being supplied via USB and no batteries I seem to have little to no issues. Installing the bottom battery seems to have no affect, removing it and installing the middle and I start having issues, leave it in and install the top battery and I lose the test signal completely.
Installing the top battery only seems to have little affect.
All supporting that it's the middle cell that is the (re-)radiator.
The point is, everyone is convinced (and I don't dispute) that the stray signal is on the center battery, and not the others. If that's true, what's the difference with the other two batteries? If there is no signal on them, why not connect/short/bond/whatever you want to split hairs on, the cases together, so that however the outer batteries are eliminating the signal can be shared by the center battery? Because IMO that's all you're doing with the tape, otherwise the people who put the foil under the foam would be seeing the same results.
The difference is the proximity to the noise source which I believe is behind the middle cell on the left side. Not sure exactly what circuit is located there, but that seems to be the source.
I wonder if wrapping the batteries up in the copper foil (minus the contacts of course) would be better than messing with the back cover...
That would likely only make for a better antenna and make the issue worse.
Is it possible that the foil/copper on the battery cover is creating a ground plane for the antenna? In the past I recall a post that mentioned running a wire from the ground ring of the earphone jack to create a ground plane that significantly increased performance.
Not likely. It's shielding the noise source and the unintended battery/re-radiator. Bearcat tried shielding the entire rear case with no benefits. If it were a counterpoise improvement, that would have resulted in some benefit, but it didn't.
Does this mean that perhaps the number after the z, being a 3, 4 or in my case a 5 means it was manufactured at different times?
The first number after the z is the year of manufacture - 3=2013 / 4=2014 and so forth. 2016 models have a 6 in that position.
Are the people with problems all using the stock rechargeable batteries that came with the scanner? From the videos I've seen it looks like it...
No. Several here have already reported many cell manufacturers.
I've been talking with 'cat' many times about this. I also did many of the same tests he has done (not sure who was first - nor does it matter).
I have also suggested many tests over the past several months - some with no benefit, and some like using the Airspy as a SA.
