BCD436HP/BCD536HP: UHF Reception Issues due to Noise from Battery Compartment
Voyager
It's present with no batteries.
Actually, I'm finding it greatly reduced (if there at all) with no batteries in the unit - particularly when you remove that middle cell. That makes sense sicne you're removing the unintended antenna (that middle cell).
KevinC
The big K
Super Moderator
I'm everywhere Focker!
Yes, but without the batteries to radiate the noise it's greatly suppressed, but still present....especially if you "sniff" around the center battery contact.
See my other comment.
D
darunimal
Guest
When did Rich try to increase the oem shield inside the case, sandwiched between the mother and daughter board, its about 1 cm more that may need to be added
D
darunimal
Guest
When did I say anything about IFX, step and modulation can make a hugh diffference if it can or can't be seen.
Rich is N9JIG, Voyager is______, since we are on a first name basis
When did the design change for anything but the literal RTC or LED components
D
darunimal
Guest
I also said in post 11 in this thread that "it was a known to improve UHF reception" to use an external antenna.
D
darunimal
Guest
This is where the oem shield could fail to be a shield.
Voyager
OK. I consider it "gone" when it no longer affects reception. But I see your side of it, too. It's still there - just not to the extent it makes a difference.
To put some context to this, I see about a 25 dB noise floor increase with the cells in, and less than a 10 dB increase with them out. This 10 dB increase is not strong enough to make it to the antenna (or very little of it), so the affect on performance is not nearly as dramatic.
With them out, I also see the source best in the area of the SD card. I removed the card and the noise is still there (at the reduced level).
Now, with the non-affected unit, the same test yields a maybe 3 dB increase right on the SD card, and that could be attributed to capacitive coupling simply making a better antenna on the probe. I see no increase at all anywhere else in the battery compartment - as in 0 dB.
I still would love to see a cap to ground from the one side of the center battery, as I believe that may be the most effective mod. But I do not have the tools to do that handy.
Voyager
Read what I said. I said he tried to shield the entire rear.
You didn't. I conducted the tests you suggested and additional similar tests. I am not limited to only the tests you propose. I will try anything I can to find the cause. I also did not criticize your suggestions or dismiss them even though I was skeptical of at least one of them.
Eye on the ball - let's try to find the solution rather then find faults with posts.
Joe if you must know. Not that it matters, and you've come up with some creative names before. :wink:
BTW Rich is Bearcat in the context I've been using.
I don't know. But I also don't know that it didn't change. If you are saying for a fact the design never changed, I would be suspect of that, but I'll let you make that statement first. I'm certainly not going to assume it is identical - especially based on the fact we know the LEDs changed, so some supporting components may have had to change as well. Ditto with the clock.
So test that theory. :D
It's odd that I'm not seeing the strongest signal in that area, but by all means test away. And please don't limit yourself to anything I suggest. If you can think of a test, by all means feel free to perform it. I really don't care who finds the cause as long as it's found and confirmed.
bearcat
I did not do that. I just put shielding tape on the inside of the plastic rear case. Are you going to try covering that shield plate? Go for it.
bearcat
What is this backlight issue I have never heard of the backlight issue the only issue I have ever heard of is the battery for the internal time clock? So the new were radios with the newer serial numbers manufactured 2016 do not have this UHF receive issue? I just don't understand how some people claim their radio works fine and others have the issue? I myself have the issue and two of my friends that have the radio also have the issue and we have radios manufactured from 2014. But when I apply the copper taped to the back of my battery door I do not see any difference except for maybe a few DMR stuff that I could not pick up a 4 comes in now. So I guess on my end that would be a little Improvement. But I am going to continue to do some more tests to see if I can fix it better.
Some may not see it if every UHF signal in their area is stronger than the noise being injected to the antenna. As I said in the beginning, this is not so much about what you are hearing but what you are not hearing. I can remove the door and lose a signal totally or on low signals removing the door introduces tons of noise on the audio. On full quieting signals I really cannot tell there is any noise problem going on. Do the door ON/OFF test. Tune to the new DMR freq you found. Remove the door while they are talking. See what happens. If the signal drops out, it is working.
D
darunimal
Guest
Do you see the yellow box in 2 pictures. See previous post.
snerd
Listening.....
Comanche County, OK
My model is a Z5, so I guess 2015? It showed improvement with the fix. I have 3 layers of copper foil tape on the back door. It is a nice, snug fit. : - )
bearcat
Air Spy Probe with Spectrum Spy
I performed a probe of my 436 using AirSpy2 and Spectrum Spy and stubby antenna on the Airspy. I know this is not a calibrated measurement device but here is what I found. I had a center freq of 460.000 and 200mhz scale.
Shielded Door Off:
I had about 30db of noise at 350 Mhz which diminished to about 20db around 410Mhz thru 480mhz. Starting at 480Mhz the noise appears to diminish to maybe 5db or so up 550mhz.
Shielded Door On
There was still about 15db of noise a 350Mhz which diminished to maybe 5db at about 410mhz and stayed at 5db up to 500mhz.
Hence more shielding somewhere should help. We just need to figure out where.
Gilligan
Hagerstown, MD
I ordered EMI Shielding conductive tape from Amazon and applied it on Friday night. The difference is night and day. My BCD436HP went from taking approximately 0.5 seconds per DMR channel to about 5-7 channels or more per second during scan. It used to take several seconds to cycle through a list of DMR sites in a Connect+ system -- now it scans it all ridiculously fast. I believe that instead of comparing signal strength before and after the tape, it may be a better test to see how long the radio sits on quiet channels instead -- if the signal strength of distant stations doesn't change, but we lowered the noise floor by applying the tape, it seems to be much more selective of what it sits waiting on now. It doesn't get delayed checking every channel so long because of the noise. Here's the tape I ordered: Tapes Master 10ft Copper Foil Tape - EMI Shielding Conductive Adhesive (1/2" Wide)
troymail
Silent Key
We're gathering more clues --
* when did you purchase your radio?
* what is the serial number (digits apparently indicate manufacture date)?
* has you unit been in for any repairs (LEDs, battery, other)?
Gilligan
Hagerstown, MD
I purchased it in March, 2014 and the serial is 376Z48000xxx. It's only been serviced by Uniden for the RTC repair. Also, I applied the tape over the foam.
