I think it may have been mentioned previously, but Close Call should also benefit from this fix. It's difficult to test this over the air due to external influences though.
Funny you should bring the 396 topic up. I checked the middle battery, positive side of my 396 today and there is the same noise on that radio, but very low level. And based on the fine performance of the 396 I was no even going to bring it up. Let us know how you make out as you apply more layers.Got my copper tape today. Applied to the battery door over the foam as most noted. Only 1 layer at this point. It's been a few hours of regular DMR scanning with no noticeable difference. It's pretty quiet though, only the usual suspects chatting away. Tomorrow I'll re-read the thread and try some of the suggested testing. My 436HP was purchased in the beginning, early March, 2014.
I wanted to mention, I applied 1 layer of tape to the battery door over the foam on my 396xt. On regular old UHF analog, I have noticed less noise in transmissions, and 1 more bar than normal on a few of the frequencies I normally monitor. This is using the RS 800MHz antenna.
That there is funny!! The second joke (I think) on this thread and they were both really good! Keep 'em coming"Customers who bought this also bought... bcd436hp."
I guess I forgot to mention. I did try some combinations or copper and aluminum without any significant findings. The person who posted the CAP fix later came back and stated he was not getting the results he thought he was at first. That certainly does not mean others cannot experiment with both of these ideasSeems like an aluminum copper sandwich would have been interesting, you didn't try that?
Seems like only one person tried a filter cap on the battery with good results way back, have others tried any capacitors?
I didn't realize how much tape was being applied to other radios so I stopped with 3 layers. I may try to add more tonight and see how much more of a difference it makes. I know it was dramatic with the shielding added so I'm curious if more layers would help.I reached the point of diminishing returns at the 6 layer mark. At that point I could place the 436 with shielded battery compartment door to about one inch of the other radios antenna. Increased noise, but not the total obliteration it was without the shielding....I would say this moves the 436 from poor to average on reception of UHF.
Just be careful to not over did it. There is a point were it will get worse. Why? I have no idea. My threshold was 6 layers. I think K3FS was 7. So your mileage may vary.I didn't realize how much tape was being applied to other radios so I stopped with 3 layers. I may try to add more tonight and see how much more of a difference it makes. I know it was dramatic with the shielding added so I'm curious if more layers would help.
Thanks!Just be careful to not over did it. There is a point were it will get worse. Why? I have no idea. My threshold was 6 layers. I think K3FS was 7. So your mileage may vary.
Thanks, I somehow missed that even though I've been trying to follow closely. Hoping to hear on the SA tests soon with more detailed information on the source and how the radiation pattern for the emission(s) is being affected by the different mods.I guess I forgot to mention. I did try some combinations or copper and aluminum without any significant findings. The person who posted the CAP fix later came back and stated he was not getting the results he thought he was at first. That certainly does not mean others cannot experiment with both of these ideas
Please post your results. I have no idea if my tape is blocking 10% of the noise or 100%.
I found a few interesting things today. I was lucky enough to have some copper tape gifted to me. I do not have an SA so my testing is done by probing with an AirSpy and Spectrum Spy software. The numbers are not intended to be true measurements. They are just comparisons between each other.
All tape was applied over the foam. I still get lesser results when I go under the foam in all cases.
All freq = MHZ
All DB numbers refer to noise floor increase when probing the middle battery plus side.
460.0000 MHZ center freq 200 MHZ span
No battery door
350 - 425 +30db
425 - 520 +20db
520 and up noise drops off
Copper Battery Door
350 - 480 +5db
480 - 550 +15db
Aluminum Battery Door
350 - 480 +10db
410 - 550 +5db
It is interesting how the peak noise when shielded is in two different areas based on the material used. So based on this if you like MILAIR use copper, if you like the 450 band use aluminum. Well not really this is one test by one person who do not have the proper equipment to make a scientific proclamation.
Also of interest. I lined the entire case with foam and covered that with aluminum. It made things worse maybe worse than an un-shielded battery case. Also I monitored the noise with each layer of copper once at six layers things were good. Layer 7 started to hear more noise, Layer #8 was about the same as the case with foam, horrible. Something must go hay wire when the foil starts getting too close to the battery. So I stopped a 6 layers and frankly I would be splitting hairs to say the copper was better than aluminum. They are about the same. If I had to pick copper would get the edge.
At this point I have two doors one copper and one aluminum. My radio is working better than ever. In fact side by side with my 396 they are about equal now. I am going to leave well enough alone and use what I have.
At some point we should have some data from the young lady who was getting some equipment on loan. I am looking forward to that. I have more spare doors on the way and will probably spray one to see how that works.
Hopefully one of the really smart folks on here or Uniden can find the miracle cure
