E etimothyd Member Joined Oct 13, 2007 Messages 47 Reaction score 9 Location Nova Scotia Jun 20, 2023 #1 UID not showing up in Recorder Log or History Log any more. Is there a way to turn this on and off or did I mess something up?
doctordialtone Member Joined Apr 18, 2009 Messages 6,415 Reaction score 3,865 Location CT Jun 20, 2023 #2 etimothyd said: Is there a way to turn this on and off Click to expand... Make sure you didn't turn off DISP UNIT ID in the settings of the scanner. Upvote 0 Downvote
E etimothyd Member Joined Oct 13, 2007 Messages 47 Reaction score 9 Location Nova Scotia Jun 21, 2023 #3 doctordialtone said: Make sure you didn't turn off DISP UNIT ID in the settings of the scanner. Click to expand... First thing I checked, but Thanks. Upvote 0 Downvote
E etimothyd Member Joined Oct 13, 2007 Messages 47 Reaction score 9 Location Nova Scotia Jun 21, 2023 #4 ProScan said: I see the UID Column is set to 'UID After Lookup' Are you using a UID Lookup.txt file? If not then can you set it to 'UID Before Lookup' in both the Options - Logging and Recorder tabs? {edit} Do you see the UIDs in the UID Logging tab? Click to expand... This fixed it for me, although I do not remember changing those settings. Thanks again ProScan. Upvote 0 Downvote
Whiskey3JMC DXplorer Premium Subscriber Joined Jul 16, 2006 Messages 10,459 Reaction score 9,164 Location Simulcastylvania, TE Jun 22, 2023 #5 Glad you & Bob figured it out Upvote 0 Downvote
