Undo system
belvdr
Turn it off: menu, set scan selection, select list to monitor, full database, set to OFF.
If running by zip code, that disables all scanning.
@longfeather1 How is your 536 programmed? Are you using zip code or your own custom favorite lists?
belvdr
i program it Sentinel Software Programming
Then edit your favorite lists and remove anything you do not want to scan or set it to Avoid. Then write it to your scanner, reboot, and enjoy!
