Unication Charger Amplifier
TexScan780D
I have the Unication Charger Amplifier to charge the radio, but he main reason is for the amplifier to hear the G5 better because of my hearing impaired. If I keep the G5 in the Charger Amplifier all the time, will this over charge the G5?
JD21960
ILL-annoyed
Not that I know. It shuts off "charging" when all lights are green. I've used it the way you do too for over a year with no problems. Mostly sitting IN the charger. Maybe Unication David can answer that better but I've had no issues.
gibby289
Is there a setting that I am missing that prevents the “snapping” sound over the speaker of the power amp? It seems at the beginning of each transmission I get this loud clicking sound over the speaker. I’m not getting this when the G5 is not in the power amp. It is almost like when someone clicks their mike. Thanks
AKJohnny
Scanner Addict
Kendall County, IL
I’ve had two of these amps, and both do this. I wouldn’t hold your breath on a fix.
