Unication for Statewide Systems
cpohlad
Midlothian, VA
So, I am about to dip my toe into the pager world and was wondering what the best practice is for programming statewide systems. I want to program items from STARS in Virginia and more specifically, Virginia State Police. What is the best way to do this in PPS?
Enjoi19
Ontario, Canada
The latest version of PPS lets you import directly from Radio Reference. It's very easy to pick talkgroups you want to hear and build a knob position for it now. You can just select the talkgroups you want and not do a massive site/tg import into PPS.
Keeping in mind to do STARS, you'll need a VHF G5 (7/800 and VHF) or look at G2/G3 options.
If you build a trunked system in PPS with multiple sites, when you select that knob it will lock on to the site with the best signal and stay with it until you lose signal, then find the next one. If you want to do 1 site at a time, you'll need to import then one at a time.
cpohlad
Midlothian, VA
Right, the one I am going to get is the VHF G5. So I could import all sites and all TGs and then just select the TG I want to monitor?
Enjoi19
Ontario, Canada
Yep, it's totally doable. You can download PPS and play around with setting it up before you get it. You can program a single TG to a knob position or a group of them.
I prefer to do specific sites and specific talkgroups on knob positions but there's nothing to say you can't dump it all in. Remember, it's really designed to monitor a single site at a time. Not sure how the speed of locking onto sites would be with a ton of control channel frequencies loaded in, maybe others can speak to that.
Latest firmware lets you hold on a talkgroup once you get a activity on it, or avoid talkgroups temporarily with traffic you don't want to hear.
IAmSixNine
Dallas, TX
Out of curiousity will you be traveling around the state to monitor the state wide system?
Or will you be monitoring it from a certain area, like your city or county?
Webodisk
Silent key.
Virginia Beach,VA
I imported the whole system, and set each knob position for a division 1-7, and set the last knob position for all the main channels & tac's works well
IAmSixNine
Dallas, TX
early on you can program just the site or sites closest to you for the system.
Then later when you have more time you can program the rest of the sites for when your travelling.
JD21960
ILL-annoyed
Instead of loading with all kinds of talk-groups and Systems. I took mine on TWO different trips through my State. One North/South thru 12 Counties on the Statewide System. The other like 9-10 Counties East/West. I added all the Control Channels of those Counties only ..didn't mess with alternates since it was just an experiment. I set up the PPS with ONE MONITOR ZONE and only one talk-group *a Wildcard (65535) It worked perfectly on both trips. Monitoring wasn't as hard as you'd think with other groups butting in. Conversations were easy to follow on the G5. That was BEFORE they added the talkgroup (HOLD) button. NOW you can simply add a MONITOR Zone under "RECEIVING MODE" scroll down on the PPS. They added that in recent PPS updates too. These days I have 4 or 5 Counties set up for ones I know I will travel to with the chosen talk-groups added. Also have a VHF zone FOR those counties too that are still being used.
The Unication Pagers are truly a great product. I can't wait to see the Unication SCANNER advertised on the Unication Taiwan site. Should be fun.
mdsxfire
EDBM
Uxbridge, north of the river Thames
i did the entire NJICS system in my G5 before the import feature, took a little bit of time but it works amazing as it just hops site to site while i move around the state, sometimes it does grab onto a site that has a weaker signal than one i know is close so i just change the knob position then go back and try to get it to grab the other site, but works great overall
