Unication G pagers having trouble programming this configuration of QCII
policefreak
Berlin, NJ
So lately with the newest firmwares and PPS, I've had trouble programming several G pagers to only break squelch for the subgroups listed on the dispatch talkgroup and nothing else. With the old PPS I would select the dispatch talkgroup in the Trunked system, make sure TONE was set to DEFAULT, then in the knob configuration under the subgroup list, I would uncheck "Alternates" so that I don't hear every dispatch on the dispatch channel, only the subgroups I have assigned to it. Recently I had gotten back several pagers I programmed saying people are hearing all the dispatches with this configuration, even though "Alternates" is still unchecked. So what gives? Is there now another new step I need to complete?
hazrat8990
Wyoming
How is the actual channel knob set up? Do you have the receiving mode set to Trunking TG-Scan? If it's set to Trunking TG-Monitor, it will receive everything on the site. Also, how do you have your reset mode configured? Try Auto Reset, and uncheck the other boxes.
This configuration will only alert and pass audio when tones are sent, and then go silent. If a delay, or different reset mode is used, it will alert and continue passing audio as long as the TG is active.
