Unication pager stun
nhfdcadet
GCT-1
New Hartford, Ct
Has anyone ever heard of a unication pager being stunned/killed by a trunking system? It was mentioned to me, but I had never heard of them even having this capability. I would assume that if the pager was programmed with no id by default, there would be no way to stun it.
GTR8000
NY/NJ Database Guy
BEE00
Yes, we experienced this firsthand a few months ago. We inhibited ID 1 on an ASTRO 25 system, and a bunch of G5 pagers responded to the command and were stunned. Would never expect a receive-only device to behave like that, but they did.
Talked about here in this thread
nhfdcadet
GCT-1
New Hartford, Ct
thanks! Here I was looking under the unication section, should have checked the Motorola section! lol
nhfdcadet
GCT-1
New Hartford, Ct
so I asked this on that other thread as well, but if you leave the unit ID on the trunked system as NO SETTING, would I be correct to assume that the pager would not receive the inhibit command?
GTR8000
NY/NJ Database Guy
BEE00
Presumably, as there would be no ID to match up with the inhibit command.
FishScan
Why would anyone assign an ID to their pagers unless they want them to be addressed or stunned individually?
  • Like
Reactions: RRR
rr60
By default 1 is assigned and enabled, at least on my Uni’s. I am using the latest
PPS. Not only that, on each and every system. I too have heard of stuns in our area.
On my UT logs I see little history of UID 1 on many systems but there are a few.
FishScan
Not true. Default is no ID.
K9KLC
Southwest, IL
I concur, în the SUID column I have "no setting". on them. IF, I click on that and hit "OK" however. it does save it as #1, and it appears "enable" is checked when you open it by double clicking but if you hit "cancel" then it saves the no setting, setting. If it already says no setting there is no reason to check would be my guess. It says to the right in the instructions, the default is "no setting".
K9KLC
Southwest, IL
This would be my guess also. if you read on the right it's to target specific pagers. That's the only reason I can think of for it to be on there.
Enjoi19
I couldn't imagine Unication buiding in an inhibit pager disabling function in the first place. Did they?
It exists. User posted it on one of the Unication facebook groups with the screen displaying "Device is Disabled"
KevinC
The big K
Super Moderator
I'm everywhere Focker!
Makes perfect sense to me, especially since they have encryption capabilities. Unication with proper keys gets lost? No problem, just inhibit it. Only drawback is the system can't tell if it's been inhibited since they are RX only.
Echo4Thirty
Spring,TX
The pagers were designed and marketed as system devices for agencies. The scanner community using them as receivers is no different that using a Motorola or Harris radio for NAS. As such, I agree with Kevin. If my fire agency lost one, I would want the ability to shut it off especially if its keyloaded.
For those asking, the devices can respond to not only QC2 paging, but call alert as well which requires a unique ID.
Treat these devices as you would any other professional system radio. I know the ranges of IDs in use on my local system and try not to pick an ID that is commonly used to illegally access a system (ID 1 for example) or put it in the range(s) that my local systems use. Any ID can be hit of course, but with 16.7 million to choose from, you can surely pick one that is lower risk that others.
