Unication PPS Operating System Requirements?
MDScanFan
USA
Where can I find info regarding the operating systems and hardware requirements to use PPS? Is it compatible with MacOS and iOS? Thanks.
K6LEH
Oakland, CA
I use the PPS on a 2017 vintage MacBook Air (Catalina OS), using Parallels. No issues.
w2lie
New York DB Admin
Long Island, NY
PPS is a windows based program. I'm running it on both Windows 7 and Windows 10.
As K6LEH said above, you can run on Mac, but you still need a Windows environment to run PPS.
MDScanFan
USA
Thanks for the information. I was not able to find it on their webpage.
I have no experience trying to run windows on a Mac. If I understand correctly I would need to buy a copy of the operating system and maybe separate software to run it (ex parallels). I am considering that route or buying a low end windows laptop.
w2lie
New York DB Admin
Long Island, NY
In order to run windows on a Mac, you have two options. Both require a copy of windows.
You can run Bootcamp and boot into windows on your Mac, or you can run Parallels.
Parallels allows you to launch a VM in your Mac to run another OS. I use Parallels on my Mac to Launch into Windows 10 and also Ubuntu.
However, I find it easier just to keep a cheap laptop running for my programming needs.
N6ML
It's actually possible to run Windows 10 without purchasing a license. Simply install it but don't activate it. Functionality is a bit limited, but it should be enough to run PPS.
VirtualBox is a free alternative to Parallels. I have run PPS in a VirtualBox VM on a Windows host, but I don't have any modern Mac hardware to try it on. Plumbing of the USB device is the only part that might be tricky.
MDScanFan
USA
I appreciate the replies. I am not savvy with macs so I am hesitant to try the windows boot or VM route. I am most likely going to purchase a low end windows 10 laptop for this. I’ve been wanting to get one for another radio related reason and this gives more of a reason to just do it.
