Uniden 796D
tassie
New Brunswick
I am having problems programing my 796D scanner for trunking and scanning the Motorola Type IIi Hybrid system.
Could some one offer to help?
Thank
Tassie
wildbillx
Cape May, NJ
796d
I too need help in programing digital and mot. II trunked systems. I am new to scanning and only have the pro 97 and 2055. Yes I did buy the arc250 pro and still cant figure it out.
seamusg
Grand Blanc, MI
Your scanner is not Uniden and stop Hi JACKING a thread.
DXKW
I have two 796s what system are you trying to program ?
wildbillx
Cape May, NJ
I just bought the 796d and need help. I was saying I also had the 97 and 2055 if anyone needed help with those!
duckbird
Texas
Thank
Tassie
Programming the BC796D For Trunking)
1. Press Menu
2. Press 2 twice
3. Select Bank
4. Press E
5. Press 1
6. Select On
7. Press E
8. Select System Type (Type2/P25 800
9. Press E
10. Press 2
11. Select Channel Number
12. Press E twice
13. Enter Frequency
14. Press E twice
15. Use VFO knob or wheel to move to next channel
16. Repeat steps 12-15 (When finished, Press Scan)
fmon
Silent Key Jan. 14, 2012
Eclipse, Virginia
This cheat sheet for the 785 will work for programming the 796.
Tassie, you will need to start at the top then move to the second part for programming the freqs then the third part for ID's.
wildbillx, you can skip the first part. However, ARC is the programming method of choice.
