BCD325P2/BCD996P2: Uniden bcd325p2 programming in wi
kastephens84
I have a uniden bcd325p2 scanner and I can hear some stuff. But some stuff I cant. I live in grant co wi. What kind of antena is best for this scanner. And setting for programing it. Some stuff is p25 and some analog. Just cant hear like car to car police traffic before they switched to digital.
Chris0516
Pittsboro, North Carolina
On this page: Grant County(WI)
It only shows These channels:
2201055faDGTSCANGrant County ScanInterop
2201155fbDGTCOMGrant County CommonMulti-Talk
WISCOM is P25p1 system. I see a lot DOC TGs' throughout the state. I don't see much De/DE. So, If the car-to-car is no longer analog(along with others), it was only updated 3/21/2026. It would need another update.
hiegtx
Dallas, TX
Looking at your county in the database, the local public safety agencies are mostly Vhf-high, with a few using Uhf. Some use P25 (digital) on conventional channels, though most are analog. If there have been changes to their usage, it has not yet been submitted to the database. I see a couple are tagged as part-time encrypted. Your 325P2 will ignore encrypted radio traffic. Other than the two talkgroups Chris posted, from the statewide system, most agencies, apparently, are not currently using that trunked system.
The Remtronix 842B is a good option for Vhf & Uhf. Another option is the RH789. That's a telescoping antenna. It has markings with suggestions on how far to extend it for desired frequency bands. The Diamond RH77CA is a good antenna for Vhf-high & Uhf, but at around 18 inches long, some may consider the length obtrusive when trying to carry the scanner around.
Are you using software for programming? (If so, which program?) You might try programming the channels as "search", and let the scanner find whether they are still analog, or have converted to digital. If you know they are P25 (digital), set the channel to digital, and "search" so that the scanner can find what NAC code is being used.
This thread in your state forum is discussing the changeover to P25 (digital).
Whiskey3JMC
_/|\_Surf's up, Happy DX!
Simulcastylvania, TE
As I pointed out to another user from Grant County, WI on this thread the sheriff appears to be conventionally simulcast across 3 sites (& Fire Dispatch across 4?) The OP would be much better off with a Uniden SDS100, 150 or 200 to compensate for simulcast distortion assuming they are in range of two or more sites on any given "simulcast". There are workarounds for the existing scanner in the simulcast distortion wiki link I provided that can be tried but the OP may or may not see improvement
