I’ve seen many threads online about making a discriminator tap. There are several versions floating around, most of them use a resistor + tantalum capacitor from the already available DISC point in serie to a RCA/3.5mm mono jack.
I get that and i used to make taps on my old scanner. From reading a lot online and also reading the tutorials from Bill Cheek, it seems that many of the old recommendations are no longer valid because people are connecting their discriminator output directly to their microphone/line in. From reading it seems there is often voltage coming from the PC since most microphone in lines power microphones this way.
from reading multiple threads it seems that a higher value tantalum capacitor of 10uF is best for a clear signal. Resistor values and suggestions vary wildly. I found people recommending between 1K and 12K Resistors. The guy from this thread: Discriminator Tap
says a lower value of around 1K should be used because it can interfere with the decoding.
this Is all getting over my head.. is there someone with true technical knowledge that can help me understand which values are best used.. thanks a lot
