Uniden BCT15X - Best way to discriminator tap for DSDPlus? Tech question
zerosix
2 pins. I used two pots to experiment and find good values for both resistors, then substituted fixed 1/8w resistors. The top of the divider will be a high value (maybe 20k to 50k) while the bottom will be much smaller.
but 2 pins is a variable resistor right? And you where talking about a voltage divider earlier.
zerosix
Okay I figured it all out and just finished the scanner! The end result is nice and it’s working quite well. I used a 10K potentiometer and 10uF capacitor. It’s nice to be able to adjust the signal. I’ve noticed from my very limited testing that a certain value can work great for nearby (stron) DMR signals but weaker NXDN or DMR signals need a slight modification to decode properly. Thank for all the wonderful suggestions. I’ll keep you guys up to date with the progress.
