Uniden future feature?
DaveIN
Founders Curmudgen
West Michigan
If the BC246T turns out to be the hit I think it will, then this could be a great feature to add to the next generation digital. I found a radio product that is using the Secure Disk/MMC for storage for recording AM/FM audio. This is an great feature that could be used and maybe it could also be set up to handle the radio memory:
Radio YourWayTM AM/FM Radio Recorder
"Record over 4 hours of AM or FM broadcasts for later playback (32MB Internal Memory)"
"Connects to your PC USB port for the transferring of files."
"SD (up to 256MB) / MMC (up to 128MB) expansion slot for adding additional memory."
Check it out: http://www.pogoproducts.com/radio_yourway.html
mciupa
Canadian DB Admin
Moderator
I'm here a lot
Yes I'm sure us working stiffs would find a device like this very
helpful while we are 9 to 5 -ing.
We could review later what we missed, then save or delete. 8)
DaveIN
Founders Curmudgen
West Michigan
Here is another thought how about APCO-25 decode during limit/service search such as the BC250D/BC296D has?
rdale
Lansing, MI
Why do you think they would remove APCO decoding in the next digital model if all current models offer that option?
DaveIN
Founders Curmudgen
West Michigan
True, if Uniden holds true to form. I'd like to keep Activity Id also.
How about a sleep timer or turn on timer. On a base/mobile like the 796 this would be great.
INDY72
Indianapolis, IN
LOL wasn't that tried before????
DaveIN
Founders Curmudgen
West Michigan
Sorry Joe, I guess I should of said low end Uniden radios.
That is a good point. An AOR feature that would be good on a Base/Mobile Uniden Traunktracker.
