Uniden SDS100 Protective Case/Clip Advice
emafireecu
North Carolina
Hello all. I have had my SDS100 for about a month now and I have found I need a protective case/holster for it. I have seen the ones on Scanner Master (hard leather) but wanted to see if anyone out there had/knew of any other brands? I really would like something that replaces the stock belt clip. The stock belt clip is less than to be desired. Any suggestions would be appreciated!
evilbrad
My head makes a bad antenna
Ive had the oem 436 and sds 100 clip swivel and fall off not fan of clip
Eng74
Kern County, CA
I have both the soft leather case and the nylon case. I like the nylon cases better. I have not tried the hard leather cases that Scanner Master sells. I like the belt clip that comes with the Scanner Master cases better than the original one from the radio. I have taken the button off of the radio so it fits better in the case.
doc62
I have the hard leather case and added rings so the I could use my fire radio strap vice carrying on the belt.
