Uniden SDS100
beema911
Hello everyone!
I just purchased a Uniden SDS100. I'm located in Haiti and I can't program it with zip code or location. I am unable to find any frequencies...
Please help.
Thank you!
Scanner996p2
PA
Hello everyone!
Please help.
Thank you!
that is because you are in haiti it won’t work in your country you would have to find local systems and frequencies yourself
Nascar18
Southeast Massachusetts
Try using the search function. 30-50, 150-160, 450-470, 480-485 and 850-870mhz. Marine traffic will be in the 156 - 158. Find the most active frequencies write them down and then use the Uniden Sentinel 100 & 200 SW to program in the scanner.
Look at the antennas on the cars. The smaller the antenna the higher the frequency.
Be careful someone might not like you listening!!
