Uniden SDS200 Stopped Receiving Traffic
RandyKuff
Lorain, Ohio
If your just using an ant on the the scanner itself... Try moving it to the area were the other scanner is and see what it does...
It may be in a dead spot for reception...
FireLt111
Assistant Fire Chief
Ashland, Kentucky
Ok, through all the outstanding advice. The scanner is still NOT responding to the adjusts. Somehow, somewhere in the course of 24 hours, this radio basically is rendered useless. Its still under warranty so I guess that would be the next option.
Still we can't understand why in the heck it will pick up on the call and drop it after 2 seconds. Unreal.
fxdscon
¯\_(ツ)_/¯
even though our Whistler scanner on the other side of the newsroom is going to town uninterrupted!
Can you re-locate the SDS200 to where the Whistler is to see if it receives better in that location? Could be some very local interference or signal blocking going on.
FireLt111
Ashland, Kentucky
You posted 4 zip attachments here. Are you having trouble with all 4 FLs or just the Boyd County 911 one?
It looks like EVERYTHING! The radio is quiet...Kentucky State Police are VERY active right now with a hostage situation and the transmissions are constant on our Whistler scanner...but nothing on the SDS200
werinshades
Chicago , IL
I had a look at your programming and might have missed this, but do you have each Favorite List set to Download ON..Monitor ON?
Under Menu..Set Scan Selection...Select Lists to Monitor..Full Database OFF...scroll down to your Favorite Lists and make sure each one is ON.
FireLt111
Ashland, Kentucky
Ok...I had the "MONITOR FULL DATABASE" on or checked...I unchecked it thus setting it off. Wrote it to the radio...so let's see how that works.
I tell ya, I am really perplexed on this. I have been working with scanners for years and this threw me.
werinshades
Chicago , IL
Did you scroll down to your Favorite Lists before you're writing it to the radio?
werinshades
Chicago , IL
Yes. Is this the screen? Everything is ON. But yet...still Dead. My head is spinning!
Yes that is it. Is their a reason why Quick Keys aren't assigned to the Favorite lists? Or...are they not on? 1 Enter..2 Enter...etc.?
FireLt111
Ashland, Kentucky
I have no idea how to use those. Never thought of that. Could you provide direction, please
werinshades
Chicago , IL
Sure...are you programming from Sentinel to the scanner, or the scanner to Sentinel?
The programming structure is different than Whistlers, so I'm sure that's the confusion. Let me try something to send to you here. Give me a little bit of time to rework this if that's ok?
FireLt111
Ashland, Kentucky
I am exclusive on Sentinel to the scanner.
Whistler is running awesome on the other side of the newsroom. :)
Yes, I can wait...no hurry sir. Thanks so much!
werinshades
Chicago , IL
Here you go. I have it set to Favorite List 0. Once you've downloaded it, Go to Profile and set it to Download ON...Monitor ON. Write to Scanner. It should be on once the scanner reboots, but if not 0 Enter will turn it on or off.
Suggestion only: once the Write to Scanner box pops up, you might want to check the Clear all Favorites List box to basically wipe the scanner clean if nothing else has worked so far.
You can Edit the name, Favorite List number later if everything is working.
  • Fire Lt.911 Kentucky Programming.zip
FireLt111
Ashland, Kentucky
Ok I have the file in my download file on my computer...how to I bring it over to Sentinal?
I'm sorry, sir.
Tim
werinshades
Chicago , IL
I'm sorry, sir.
Tim
No problem. It has to be converted to an hpe file, then..File...Import hpe File...File..Save. Then make sure it's set to Monitor and Download ON under the Edit Profile tab in Sentinel. Then Write to Scanner.
FireLt111
Ashland, Kentucky
Thanks. OK, I uploaded and wrote to scanner. Sadly, nothing. I think she's DOA.
