Thanks. OK, I uploaded and wrote to scanner. Sadly, nothing. I think she's DOA.
Monitor..Download set to ON? Pressing 0 Enter do anything?
Did you perform the Clear User Data procedure mentioned earlier? Check the box to Display all Drives?
Ok gang...after doing all the advice and directions...I am calling the coroner and declaring it DOA. The scanner is dead. It did, however, pick up the NWS. Go figure.
Thanks guys!
Pamela Lee
News & Weather Director for X Rock Radio
www.thexrock.com
When the scanner is on after all of this, what do you see on the display?
When you press 0 Enter, what happens?
Ok...the screen shows the scanner actively scanning. Periodically, it will stop on a P25 channel and you will traffic for about 2 seconds...then it continues to scan afterward....even though the traffic is continuing on the Whistler scanner.
When I press 0 (zero) it shows this: see attached...
It does nothing
You need to press the "E" key after zero if you're trying to enable a quick keyWhen I press 0 (zero) it shows this: see attached...
Next time it stops on a channel try quickly pressing the Channel button to HOLD on that channel. Is the transmission still interrupted when held on that channel?Ok...the screen shows the scanner actively scanning. Periodically, it will stop on a P25 channel and you will traffic for about 2 seconds...then it continues to scan afterward....
YES, it will have traffic on it for about 2 seconds and then stops. Like I said, the Whsitler continues to sing like a bird...the SDS200...NOPE it just stops.
This wouldn't explain the interruptions every 2 seconds though and it doesn't appear as if priority scan is enabled either (PRI would show up on screen if it were) Anyway to turn off full database without Sentinel, press Menu knob then scroll to Set Scan Selection > Select Lists to Monitor > Full Database: Off. Only the favorites lists containing what you want to monitor should be set "On"Based on that screen shot, it appears you are still scanning the Full Database.
Based on that screen shot, it appears you are still scanning the Full Database. There is a couple of check boxes you'll need to uncheck then re write to scanner. Also you should Erase All Favorite Lists to limit your scanning to 1 favorite list.
Under profile..uncheck write full database. Your also prompted in the Write to Scanner box. Uncheck them.
I just cleared everything out once again. I am ONLY writing Boyd County system in the radio. I will keep monitor/download OFF and re-write.
Then we will start again from there.
