unit ids
UPMan
In Memoriam
Arlington, TX
Yes. Program the ones you want into a channel and tag them.
mclove
HAMILTOIN CANADA
i now how to tag the id i want tag the radio ids so i no who is who can u do that ?
UPMan
In Memoriam
Arlington, TX
I'm sorry, but I cannot understand your question in its current form.
sjlamb
Sarasota County, FL
It's done the same way that you would tag a talkgroup ID. Just program the unit ID into the scanner the same as you would program a talkgroup ID.... ex: i54321.... then tag it with any name you like.
mclove
HAMILTOIN CANADA
Unit ids
Ok what im trying to say is how do i tag the unit id ok i have trunk id 48-tag withe the name east-end police ok the unit id for dispatch comes up (201) i wood like to tag that the unit id with the name (dispatch) so eveytime thae unit id shows it will say dispatch it always the same unit id always (201)just want to tag that unit id how do i do that ? Thanks
Kennrth
Bay Shore Long Island NY
I have the latest FreeScan and ARC XT Software. I see no provisions for doing this in scanner menus or software. But I do see Unit id's in logging area of ARC XT software virtual mode. Otherwise I know no way of doing this on bcd996xt.
There are no provisions to scan id's either. Only Talk Groups.
Id's I think are a sub group of talk groups - individual members of a talk group that is. For security reasons probably best left alone.
UPMan
In Memoriam
Arlington, TX
Program the unit id into a channel. Program an alpha tag for that channel.
sjlamb
Sarasota County, FL
Don't know how to make this any easier. It is the same as I have already stated:
Press: MENU
Select: PROGRAM SYSTEM
Scroll to and Select the SYSTEM that you want to put that Unit ID in
Select: EDIT GROUP
Scroll to and Select the Group that you want that Unit ID in
Select: EDIT CHANNEL
Scroll to and Select: NEW CHANNEL
Enter in the Unit ID: i201 (Must Begin with the letter " i " ).
Press: E/yes
Select: EDIT NAME
Type: "Dispatch" or Whatever else you want to call it
Press: E/yes
This is how you add and/or edit a Unit ID with alpha tagging. If you're asking something else.... I'm at a loss as to what you're trying to do.
sjlamb
Sarasota County, FL
i just like to say thank u upman and sjlamb for the help
You're most welcome. Glad to hear that you were able to get it programmed the way you wanted.
If you are using software to program the scanner; you will now find that when you download from the scanner, the unit ID and the alpha tag you created will appear in the same list as the talkgroup IDs for that particular Group. Adding a bunch of Unit IDs with your own alpha tags is done much faster and easier by using programming software than the manual procedure detailed earlier. Enjoy.
