I take it no one has come up with the actual channel mapping for United Site 1-14? I have been trying to play wack-a-mole watching the streams as they pop up on the waterfall and match them up to the LCN that DSD-FME shows as active. I'm getting nowhere. I even tried the DMR TIII LCN calculator. But, I don't know if my observations are correct for the Ref Freq/ Ref LCN. So garbage in == garbage out.
Mike
Whatever it is, it's a mess - even looking at the Chicago site in RRDB the channel mapping makes no sense.
Typically, you have a single mapping plan across all sites, but since they're in UHF/T-Band/800Mhz/900Mhz they have distinct ones for each, so it's likely going to take some patience to find the first frequency-LCN combination, and then the rest can be calculated (Chicago is 12.5 KHz spacing in the frequency calculator, so I would think IAH would be the same).
The way I solve it is I use a SDS100 (with the DMR add-on), with all the frequencies loaded as conventional, and will start scanning them, but watching the control channel with DSD. When the scanner stops scanning on an active channel, note the LSN DSD is reporting. Rinse and repeat. Get a couple of LSN pairs and then go to town mapping the rest with the calculator. Depending on the level of activity (and if the administrators have it set to round-robin the channels, vs using a specific channel order with one taking the brunt of the load), it can take minutes, or it can take days.
