Unitrunker Unitrunker P25 Phase 2
S
simpilo
Guest
I am running the 32 bit Unitrunker 1.0.33.6 on Windows 7. It appears to be decoding the control channel fine BUT the thing won't send any audio to DSDPlus. I do have P25 enabled in the Voice receiver. Any suggestions? (Yes I have DSdPlus 2.165 FL. I want to toy with Unitrunker) Yes I have VB-Cables setup right and also Unitrunker is set up to route digital audio to VB-Audio cable and it is set as default device and DSPlus sees it as audio device 1 and sends audio output to device 2 which has been working with Provoice. Just voice following not sending the P25 Phase 2 data to DSDPlus. Frequency should be lit green on a active frequency but that's not happening.
slicerwizard
Toronto, Ontario
DSD+ won't decode Phase II voice from anything other than a full DSD+ CC+VC trunk tracking setup. Even parking FMP24 on a Phase II voice channel gets you nowhere.
foxtail
Niagara Region Canada
Drop linux op25 on older pc...and away you go...
I'm running Dell d620 with rtl., linux op25 and phase 2
40 for the laptop, 30 for the 120gb ssd, op25 setup...priceless......
moonbounce
Which version of Linux are you using?
DRL-XM43
Durham Region
I run Linux in a VB on windows, op25 runs great on it doing P25 phase II. (Linux mint 19.1)
I also do P25 phase II on windows using FMP24 and DSD+
Either way is great.
moonbounce
So the Dell d620 handles this with no probs? I have a D630 I was looking to do same as you but I want to install a Linux version on the D630 with a new SSD, I just wasn't sure which version of Linux to use.
MB
S
simpilo
Guest
I thought OP25 switched to x64. I am running Windows 7 Home Premium SP1 on a Dell Latitude D610. Running DSDplus Fast Lane 2.165 fairly decent
45 percent cpu max usage. Linux is not for me because I dont have the aptitude. If OP25 will run on my system Ill try it if the developer switched from GNU Radio dependencies. All those dependencies just ruins my way of enjoying the hobby. I also dont want to install Oracle Java. Heck no.
foxtail
It will run on a Dell D630. I had one before, friend has now.
I'm trying to see what's the lowest Machines I have that will run op25 without any lag.
Don't bother with the n270 atom...
foxtail
Don't know what you mean by "switched to x64"
I'm running the 64-bit version of Ubuntu 18.04...which my hardware will accept.
But I can also run 32-bit version if the hardware calls for it...no what I mean?
boatbod
Talbot Co, MD
op25 does require gnuradio but it handles the installation of all dependencies itself (just run the install.sh script). It also will run on a Raspberry PI 3 which is about as low spec as it can go before the just isn't enough cpu.
