The text below was copied from the rtl-sdr web site where I purchased the dongles.
Decoding Digital Voice (P25/DMR/Mototrbo/NXDN/ProVoice)
Decoding of unencrypted digital voice signals like P25/DMR/Mototrbo can be set up in the same way as the analog system shown above. However, instead of outputting audio to the speakers, audio should be output to a virtual audio pipe such as Virtual Audio Cable (VAC) or VB Cable using the Digital Output audio selection in Unitrunker. Then DSD+ should be used to listen to the audio pipe. Audio will only be piped to the Digital Output during a digital call.
Unitrunker Digital Audio Output
DSD+ is a program that is capable of decoding digital voice protocols such as P25, DMR/Mototrbo, NXDN and ProVoice. It is not capable of decoding encrypted digital voice channels. DSD+ is similar to DSD 1.6, but it has vastly improved decoding in terms of voice quality. You can find the latest download for DSD+ in this RadioReference forum thread. As the thread is long, a direct download to version 1.51 is linked here.
To run DSD+ simply double click on DSDPlus.exe. This will open up several windows. DSD+ will listen to the default sound device in the Windows audio recording properties.
Make sure that the Deemphasis option in Unitrunker is turned OFF for the voice receiver to make it work with DSD+.
