UniTrunker
enosjones
Price, Utah
I got 2 audio cables today and have been working on Unitrunker. My Queston is what setting does Unitrunker have to be on to recieve info From one of the UCAN sites? It does fine picking up the Questar Site and all its info and even the 952MHZ site which it says its a ProVoice site. But on Ucan No Signal. should I switch it from Motorola to hexidecimal or decimal?
gldavis
KE7MQF
Bountiful, UT
First, assuming that you are tuned to a control channel (there are many to chose from), next, you have the Disc audio from the radio going to the computer (I've noticed that an Attenuating cable does not work), the setting I have are:
[Motorola]-is set to 800 Mhz North America
Auto Save-on
Display mode-Decimal
Ignore sync-no
Signal is-auto
Decoder is-online
Loggin is-off (my preference)
APCO P25 is-on
Hope this helps.
If it says "ProVoice", you've found a ProVoice voice channel (not a control channel).
Control channel detection is automatic. As gldavis suggests - make sure P25 is turned on.
enosjones
Price, Utah
Okay next question
Okay, I got Ucan's and Questar's info now how do I get it in a screenshot to post here? I will probably need bnielson on this one or gldavis.
[Alt][PrtSc] will make a snapshot of the current window. [PrtSc] will take a snapshot of the whole screen. Use [Ctrl]-V to paste the screenshot into a program like MS Paint so that you can see the image and save it to a file. I suggest saving it in a compressed format like PNG.
enosjones
Price, Utah
Unitrunker only copies one voice channel
I got unitrunker working, however it will one decode one of the 2 voice channels the 867.3875 will decode fine through the CC 866.3875, when 868.325 is active it is blank on unitrunker as if there is no activity. The 868.325 voice channel in unitrunker follows the secondary CC 866.900 channel in the list which hardly is ever used. Is this normal? or is there something i need to do?
If at any time you're uncertain about the display, press "F5" to force the program to refresh the display.
The channels are ordered by channel number, not frequency. Go to [V]iew -> [C]hannels to see the channel numbers.
enosjones
Price, Utah
Ok but its still at the bottom
This may be due to a less than perfect decode rate. Usually the program will catch the call already in progress.
If you see this as consistent behavior - please let me know.
enosjones
Price, Utah
The 2 channels alternate all the time. It might be a fluke today, but the one has 300+ hits and the other has 1. 868.325 is usually the stronger signal of the 2. Although the quality (signal?) is ranging between 25%-80%, there is no constant quality signal its all over the place.
enosjones
Price, Utah
Unitrunker Users For Site 38 Ford Ridge
Here's the users list so far for Ford Ridge.
enosjones
Price, Utah
Well i was going to upload some pics from Unitrunker, but nothing will upload. it all fails.
enosjones
Price, Utah
all my trunker pics are to big for the servers to upload to the forum or to wiki. so i guess i'll just have to do something else with them.
enosjones
Price, Utah
I tried Png it said invalid format. Qlajlu said to downsize them. i'll try that, also finally got affilliations and 868.950 on it, but i think 868.325 is just weaker quality not signal, cuz it picked up some things just not many it still misses some. when i get it working u'll know cuz i'll have them all posted here.
enosjones
Price, Utah
Ok got one to work lets see if you guys can see it.
enosjones
Price, Utah
Got it working!
He He! I got the hang of it! Here is some more!
