Unity Xg100p
agillis91
Received a lot of unity xg100 p. For our emergency management team, pre programmed for interop, we want to add local stuff and some starcom. We have a cable and advanced access control key. We have done some research about software and am unsure about what we actually need. Is it programmer or rpm?
Thanks in advance.
prcguy
I think you want a recent RPM to program some specific frequencies and maybe some "scratchpad" channels that you can FPP edit when needed. You can use Bluetooth and do this without a programming cable.
Thanks in advance.
TDR-94
Thanks in advance.
The current version of RPM to purchase is RPM2.
TDR-94
Will RPM2 program the XG-100P? I use RPM v14.
RPM14 was the last version of RPM to support the XG-100P. RPM2 doesn't support the XG-100P. If the XG-100P is the only radio that you are looking to program, then RPM2 isn't needed.
rescue161
KE4FHH
Hubert, NC
TDR-94 is correct about the 100P not being supported in RPM2. Also, for wide-band operation, you must not have Option 50 enabled. If Option 50 is enabled, you are stuck with narrow-band frequencies, except for 144-148 and a select few other frequencies, like the marine band. If you need a wideband frequency for UHF amateur or GMRS and have Option 50, you are out of luck.
prcguy
I don't think this is true, some people have been able to get radios wide banded and I have not heard option 50 gets in the way.
rescue161
KE4FHH
Hubert, NC
I have several OMAP radios and all of them have Option 50 and none of them can be programmed for wide-band, other than the few VHF frequencies (2 meter ham, marine, etc). We have two at work that do not have Option 50 and they can be programmed for wide-band. One is an XG100P and the other is an XG100M. All OMAP radios suffer this problem. I have an XL185 that I cannot use with a UHF wide-band frequency due to it having Option 50 enabled.
I sent a request to Harris (through my dealer) to have that option removed, but they denied it based on Part 90 rules. Even after I explained that I own repeaters that are exempt from the narrow-band regulation and signing their release of obligation, they still refused.
At the time (3rd Quarter, 2019), I was using the most recent firmware from TechLink. They certainly could have released a newer firmware revision that exempts the UHF ham and GMRS frequencies, but I have my doubts.
TDR-94
I believe the Unity radios have a separate option for Wideband Disable. It's option 58 (Unity Wideband Disable) or it will just have it spelled out in the feature menu as WIDEBAND DISABLED.
I've had a couple "true" full featured XG-100P's with the Harris demo feature strings,which enables all 80 features available to Harris radios, and they had option 50 (OMAP Wideband Disabled) enabled in them and not option 58. Wideband channels could be programmed with no issue, even with option 50 enabled.
rescue161
KE4FHH
Hubert, NC
I was wrong about Option 50 on the Unity product line. It is Option 58 for the XG100. I am sorry that I posted that wrong info. Option 50 still holds true for OMAP radios. I have a mixture of both Unity and OMAP. Again, sorry for the misinformation.
rescue161
KE4FHH
Hubert, NC
On the above posts where I have 50, just replace that with 58 for the Unity portable and mobile radios.
TDR-94
No need to apologize,we all get a little confused at times.Frankly,the whole subject of wideband has been rout with confusion when it pertains to the XG-100P. Similar to the subject of Phase 2 and the P7200 ;).
I have seen just option 50 enabled in XG-100P's before. I think even L3HARRIS may have confused the two features, and which radios they pertain to, more than a few times themselves!
AESFTW
Fultondale, AL
RPM2 does support the XG100 along with the 25 and 75.
TDR-94
Are you referring to the XG-100M or the XG-100P. I've seen several SRN's that state the XG-100P is not supported by RPM2.
Here is the latest XLP Firmware Software Release Notes statement.
AESFTW
Fultondale, AL
I will test it today.
TDR-94
RPM SRN also states that it's not supported.
