Unselected deck mute when key up
Malone92
i have a nx-5700,5800 dual deck setup single head kch-20R dual speaker setup
ive seen somewhere what you can have the unselected Deck mute when you key up to transmit but i can not find it or figure it out for the life of me
NXDN, P25
dual speaker setup
KPG-D1N software
Is this for amateur radio use where there is a linked 2 meter and 70 centimeter repeater?
I believe there is a speaker mute pin that can be set up on the DB25. You'd need to build a cable and set up the pins so TX on one radio would mute the speaker on the other.
