Been a happy owner of the GRE/PSR-410 for almost 10 years. It's performed well for what I wanted. I'm changing vehicles, installing a dual band radio and would like to update my scanner at the same time. Perused RR for a while, read through many OPINIONs about different units. I did have my mind initially set on a TRX-2 with the primary draw that it has a remote head. After looking at the debates between Whistler and Uniden, I'm starting to have second thoughts and maybe go the BCD996P2 route.
To help cut through my "paralysis by analysis" I thought I'd reach out to the local scene for suggestions. Bear in mind that UCAN is currently analog trunked with plans to go to P25 and at least phase I with NXDN if not moving onto phase II by the end of 2023. No plans that I've seen going encrypted - YET.
So buddrousa is satisfied for his criteria - here goes:
- What is it you want to hear? (Police, Fire, EMS, what is the range you expect (how far do you want to hear)?
- All public safety, some amateur - 15 miles (I know antenna type and mount dependent)
- Where are you located?
- Homebase North Utah County, Install will be mobile and used mobile
- What is your budget?
- Scanner – Max out at $500 for the scanner (I already have the antenna and mount. NMO with a Larsen 150/450/800 antenna)
- Do your homework, What Type Systems are in use in your area?
- Currently trunking analog with a transition to P25 phase I and then phase II, and will include NXDN within 3 years.
- How technological savvy are you?
- Reasonably so, ham radio licensed and work in a technical field. Also have resources
- Do you want a Base Mobile or Handheld?
- Base/mobile (see #2), but if better, will consider a handheld.
- Do you understand BASIC COMPUTER COMMANDS (DOS COMMANDS)?
- Yes, old enough when those came out on stone tablets and enjoyed optimizing the x286 start files.
- If needed can you put up your own outside antenna?
- Yes, installing a mobile dual band in a vehicle currently.
