input -> monitor source audio always
I definitely have tried reducing the gain. Is there a way for me to "unmute" the control channel within DSD+ so I can temporarily hear it?
Something similar to how I can unmute the CC in Unitrunker just to confirm I can hear it.
You can't monitor the control channel with DSDPlus because DSDPlus doesn't handle Motorola Type II control channels. You could monitor the voice channels though since they are P25 -- but not the control channel.
I make a batch file called "start.bat":I think I may have missed running all of the files required (FMP24-VC as you mentioned). I do now see a link .
So I see there are 4 files required to run all of this - is there any way to start them all at the same time?
Happy I got this going now
@echo off
start fmp-cc.bat
start fmp-vc.bat
start cc.bat
start vc.bat
exit
rem original
rem FMP -i1 -o20001 -P0.0 -f935.0
rem Columbus City
rem FMP24 -i2 -o2 -P0 -b12.5 -f859.2125
FMP24 -i2 -o2 -P0 -b12.5 -f851.4125
rem Columbus MARCS
rem FMP24 -i2 -o2 -P0 -b12.5 -f774.28125
rem Franklin County
rem FMP24 -i2 -o2 -P0 -b12.5 -f857.6125
Probably want to call it something other than "start.bat" to avoid the ambiguity ("start" is a DOS command).I make a batch file called "start.bat":
Code:@echo off start fmp-cc.bat start fmp-vc.bat start cc.bat start vc.bat exit
In my fmp-cc.bat I'll have multiple command line entries for the different systems I may want to monitor. I just add "rem" in front of the ones I'm not listening to and remove the "rem" from the one I want. Such as:
Code:rem original rem FMP -i1 -o20001 -P0.0 -f935.0 rem Columbus City rem FMP24 -i2 -o2 -P0 -b12.5 -f859.2125 FMP24 -i2 -o2 -P0 -b12.5 -f851.4125 rem Columbus MARCS rem FMP24 -i2 -o2 -P0 -b12.5 -f774.28125 rem Franklin County rem FMP24 -i2 -o2 -P0 -b12.5 -f857.6125
You know that's a great point. I don't get to play with DSD+ very often. There's probably a bunch of cool things it does that I miss. Just today I was looking for a way to load what I think is a NXDN site so it's scanned. There doesn't seem to be a control channel or if there is I'm missing it. The site's not in the RR DB and I am waiting on my scanner to arrive to scan it. Does a DSD+ for dummies type video exist?It would be much simpler to use the site loader file. And set the startup options to auto load the last-monitored system.
