Got my psr800 back today from Whistler after they did my upgrade and seemed good.
I was checking out the CPU upgrade and did the check on the cpu version and it was the latest so I unplug the scanner and the Boot version on the screen would not turn off.
I disconnected the usb cable and then had plug it back in and it said CPU SW Upgrade: upgrading - wait.
So I was forced to go through the ws1080/1088 CPU Update Utility 4.8 from the start and try to get it to work.
When it starts the TEST is applied it says
"The scanner currently contains no cpu application code! This update utility contains version 4.8."
I then click UPDATE and it goes through the "Upgrading CPU"
Then it says "waiting for cpu approval" and then "Scanner Response Timeout"
Anyone have this happen or have a solution to get it back working. ?
