USB and SDR Help
Bonkk083
Union, SC
When I connect a RSP1B and a Airspy R2 using a 2.0 hub that is 248msp they don't work can only use one will a 3.0 hub that's 5gbps will that help to use both at the same time
32dave
Oxford County, Ontario Canada
I am using a Dell r630 for my sdr 's but I had to run two rtl-sdrs to the one usb 3.0 through a hub other wise it was broken up and horrible the hub made a big difference so it might help. I have never used a RSP so I'm going to throw this out there could it be a power issue ?
Bonkk083
Union, SC
How can I find the power of the sdr
KE5MC
Lewisville, TX
USB power monitor dongle. It is like a common volt-ohm meter, but leads replaced with USB connectors male on one side and female on other. Plugged Inline with cable and devices. Check out Amazon, usually in the 10–15 dollar range last I looked, but more can be spent with added features.
32dave
I don't have a dongle so it was mostly trial and error you can try one at a time by themselves or a powered usb hub see if it improves
BinaryMode
Banned
2600 dialtone blvd
Is the USB hub a POWERED USB hub? That may be the reason as to why you can only use one SDR dongle at a time. It's probably a power thing more than a bandwidth issue.
This is a powered hub that should include a UL listed power adapter. Which is what I personally look for when buying electronics for safety reasons. A lot of these companies don't UL list anything let alone indicate if their product is UL listed. To me they should list that on the product page which would not only be great for marketing, but to help inform the customer. A lot of people actully want to know if this or that product is UL listed. ETL I could care less. Then again, that might be because I'm a "fat American..." LOL
I also have my doubts many of these companies are even ISO 9001 either! (Although Wikipedia indicates China is #1.) But Amazon and the baled headed "dude" are making the bucks on cheap crap I tell you.
Here are several USB power meters. YMMV on actual accuracy... Plug the meter into the computer and the USB hub into the other side of the meter and measure your Amp draw from your SDR's. If it's hitting 500+ mA (half an Amp) you're pulling too much juice and need a powered USB hub.
C_615
Can you give us your computer specs?
Bonkk083
Union, SC
Your problem is almost certainly your use of a USB 2.0 hub. Get a USB 3.0 hub and try again. FWIW, I don’t use a powered one in my setup and have it completely maxed out with SDR devices.
My computer has one USB port and I have a mouse connected to the hub and the sdr could I plug I a powered hub for sdrs nto to a 3.0 hub
C_615
The spec sheet I am looking at for the Samsung NP950QDB shows two USB type c ports and 1 Thunderbolt 4.
C_615
Have you tried running the SDRs off separate ports, including the Thunderbolt port? If the max SDR devices you want to use is the two you are currently using, you should be able to make it work with some trial and error. It helps if you have an application that will provide the USB mapping details. I had to do that on my Linux machines. I don’t know what the Windows equivalents are.
Bonkk083
Union, SC
I have tried a 3.0 USB 4 port hub and a 3.0 powered USB the RSP1B won't work with a USB 3.0 it will with a 2.0 and tried the hubs on another computer no change and I can't run two Sdrs on both computers, What kind of computer would I need to get with more power to run both at the same time
merlin
DN32su
All USB ports have a power limit of 500 Ma. All USB powered dongles use a lot of power.
My suggestion is a 4 port USB 3 externally powered hub. Use a USB 3 port for that and likely sove some issues.
Use a USB 2 port if your SDR recomends that.
C_615
Go to
  • Windows: Check Device Manager → Universal Serial Bus controllers
And tell us what it shows.
I suspect you might have only one USB controller. In my experience, I have only been able to get at most 13 MHz of bandwidth per USB Controller. Regardless of whether the port is 3.0 or 2.0. I think the issue is that the SDR devices themselves are 2.0.
Bonkk083
Union, SC
Go to
Integrated webcam hd
Intel usb 3.1 extensible host controller 1.10
Usb composite device
Usb root hub usb 3.0
I plugged the Airspy back in the pc it hasn't worked right since I used the powered hub with sdrtrunk same settings nothing like it was now it skips but the cc stays on something isn't right done tried all ports
