USB cable for IC-R10, IC-R72, IC-R75, IC-78, IC-R7000, IC-R7100, IC-R8500
AronDouglas
Southeast Georiga
Has anyone deconstructed one of these? Its just a USB to male 3.5mm mono jack. A USB is 4 wires and a mono jack can only be 2 wires, so this shouldn't be a hard thing to figure out. I've done loads of USB hacks in my day, so this should be fiarly simple. If no one has done this yet the I will (unwillingly) spend the $20 and do the hack myself and let everyone know how its done.
n9mxq
Belvidere IL
There are plans all over the place for those. Have been for years...
Comint
Queensland, Australia
Even though the IC-R10 has an actual CI-V socket on the side, programming is usually done through the Speaker Socket, which requires a Stereo 3.5 mm Plug, with the Data on the Ring.
Even the genuine Icom OPC-478 Serial cable was set up for the Speaker Socket.
Comint
AronDouglas
Southeast Georiga
You are so nice :) I love that google feature.
I didn't see any links on RR, guess no one has posted it here...or I just missed it.
n0nhp
Grand Junction
If you have a Radioshack or GRE Scanner programming cable, you have a CI-V cable for Icom radios. Been using both the older model and the current model for several years very successfully.
Bruce
