banjo5stringleon
When programming your sds100 with Sentinel. How do you know which MARCS-IP you are to use. On some counties it gives you three to choose from.
I’m a newbie and trying to learn the programming.
I had something happened to my SD card. I believe I loaded to much info when I was loading MARCS-IP. When I noticed that sentinel was taking a long time to load the scanner. It was to late. I canceled the loading and my sds100 now just gives me a readout SD card file error. Use sentinel “Clear User Data” operation to initialize SD card.
Whenever I hook back up to sentinel it will not go back into the data base on the scanner as it should. It’s locked in and gives that read out every time.
I don’t know how to fix the problem. I did back up everything I had before I messed up programing MARC-IP on the scanner. And now hooking back up to sentinel or just turning on the scanner I get that read out every time. It is locked on that. Plus when I go to shut off the scanner it takes longer than usual to shut down.
I did buy a new sd card reader and an extra card just in case. I’d hate to loose the data on the card if I have to reformat. But I do have all of the programming that came on the scanner that was done from the pro’s, knowing I needed there help. Any suggestions from anyone on how to unlock the screen? Would be appreciated. Thanks. And still a Newbie.
