Using separate RX and TX antennas for a repeater
WRMD298
Roger on the above. I'm open minded enough to understand that each situation may be different. Thanks for the replies and sorry for hijacking the original post.
prcguy
I cant agree with the "top antenna has the most noise". I have multiple,as in many DB-224's top mounted on 400 +foot towers and and able to add preamps to the receivers and still not problematic noise.
Got to be something else.
Same here but all the sites I’ve used reserve the top rung for receive only antennas. I’ve always had better receive from a top of tower receive only antenna feeding a good preselector then preamp to multiple receivers. Never had any noise problems. I’ve also not heard of a problem like this except for a few specific systems that had something wrong like passive IMD from tower/antenna mount corrosion or something similar.
WB5UOM
Here its whatever where ever. Tx Rx doesnt matter
Ubbe
Stockholm, Sweden
I've had a microwave link generate RF smog at a 10uV level from a 400MHz antenna 2 meter behind its dish. Moving my antenna 10 meter in front of the dish got rid of all the smog. It had to come from the electronics and not the microwave RF signal.
Some rotating top lights can be a nuisance, especially if they are the LED ones and its sliding contacts can behave differently depending of the weather.
/Ubbe
