Wouxun UV9PX RX Cutting Outng Out
WRUW515
I have a Wouxun KG-UV9P Series HT. When I am receiving a transmission, the radio cuts out every few seconds. The RX LED indicator and audio both cut out. They only way I have been able to get this to stop is if I have both the A and B receiver set at the same frequency. Is there a setting I need to change to receive properly without having both A/B on the same frequency?
rescuecomm
Travelers Rest, SC
Probably the radio sampling the other receive frequency. Turn the TDS off in the menu. These radio designs don't have real dual receivers.
FKimble
Newnan, GA
Or maybe you have a priority set and it is sampling that. Or even sampling weatherNOAA if that is enabled.
Frank
