V1.4 beta question
minasha
NYC
I received my 1.4 beta firmware from Unication. Is this beta program tied to a serial number
or can I load it on any G4 or G5 ?
N6ML
Unless you got something different from me, one of the notes in the email should say:
"This upgrade utility was only available for the special MSN list, if you testing pager MSN is not on the list, please contact us "
Suggest reading the notes carefully - there are some caveats to be aware of.
minasha
NYC
I don't remember if we had to enter our serial number to get the 1.4 beta program did we?
If yes the files they sent me are useless because I have a different pager now.
Synchro39
Montreal Quebec
yes it's useless if the pager you have now is not the same you register to get beta 1.4 you won't be able to load it
N6ML
I did.
I've also had my G5 replaced under warranty since, so I'm in the same boat.... but I'm not in a big hurry to lock myself into V1.40 right now anyway.
Hit_Factor
Saint Joseph, MI
I did.
Didn't Dave say he reverted back to 1.3 without problems?
N6ML
I don't know who Dave is.. but there have been several strong warnings that once you go to V1.40, you cannot go back.
N6ML
I got the name wrong, it was Kevin. G-Series Trunking Free Scan Beta Test II
Right... so apparently he's been able to do it, and hasn't noticed any ill-effects so-far, but that doesn't make it supported.
My guess (and it's only a guess) is that V1.40 updates some components of the pager's operating system that are not delivered with the V1.30 and earlier releases, so if you upgrade to V1.40, then reload V1.30 (or earlier), those components will be newer than the versions that V1.30 (and earlier) were tested with.
Maybe you can get away with this (apparently Kevin has), but (I believe) it's not a supported configuration.
Hit_Factor
Saint Joseph, MI
I went from 1.4 back to 1.3 and have not noticed anything issues at all.
I suppose the firmware could write a whole new partition, and there are not any remnants from 1.4, I don't know. Or it could be like Windows and be a mish mash of old and new like N6ML suggested earlier.
