vehicle repeaters
When using a vrs it is reccomended the mobike be uhf and the portable vhf OR vhf mobile and uhf portable. The bandwidth separation is 12.5 narrow. The vrs portables typically put out a low wattage. The mobile typically can be set to rebroadcast narrow while the portable is wide but may have some issues or none. It's reccomended to keep both narrow. With newer vrs equipment many use 700 mhz for vrs portables while using uhf or vhf mobiles. Honestly if your running a small operation running wide you'd prob get away with until you upgrade to narrow. But it's a risk but not noticeable unless someone reports it. I wouldn't reccomend it but some do it. You'd need to be licensed for the vrs int freq and mobile freq. This is to ensure no one else uses the freq such as a public safety agency.
What type of vrs unit is it you are using and mobile? This would help others find the documents you ask for.
whirley1
wichita, ks
unknown, doesn't say. model y1082, fcc # abz89fr3698 serial # 583hm0126. It came from Pa state police when they went to skynet or somethin or other
kayn1n32008
ØÆSØ Say it, say 'ENCRYPTION'
Sector 001
Regardless, the HT-600's and the Syntor can not be used for part 90 frequencies anymore...
Sent from my iPad using Tapatalk
If you used it as a ham and did a ham vrs and a monitor type radio also you'd be legit in wideband.
whirley1
wichita, ks
i just bought a bunch of vhf syntor x9000 radios and they came with sirens and repeaters (y1082A). Can anyone tell me about these repeaters? I was told that the Y stood for vhf. Is this correct? Thanks, Don 73"s merry xmas
cmdrwill
So Cali
Those are NOT really repeaters. Rather an Extender, AKA Vehicle Repeater, they add a way for a handheld to talk to the car and the big radio in the car talks to the station. The car radio receives the station, and the VR retransmits on low power to the handheld.
VR is a low power transceiver.
whirley1
wichita, ks
repeaters
that sounds great, now to the question, is this vhf or uhf, That's what I need to know 73's
kayn1n32008
Sector 001
Regardless, the equipment can't be used for what you want to use it for
Project25_MASTR
TX-COMU
Texas
Depends on what the radios are for. If it's VHF, the bi-directional cross band will have a low power UHF radio. If it's low band it could be either UHF or VHF for low power.
Probably would be. A decent setup for a split site repeater.
