vehicle repeaters
kayn1n32008
ØÆSØ Say it, say 'ENCRYPTION'
Sector 001
Depends on what the radios are for. If it's VHF, the bi-directional cross band will have a low power UHF radio. If it's low band it could be either UHF or VHF for low power.
Probably would be. A decent setup for a split site repeater.
In his other thread he wants to use it for 'security and other stuff' none of the equipment is narrowband capable...
Sent from my iPad using Tapatalk
Project25_MASTR
TX-COMU
Texas
Ah. For ham use they'd be fine though.
Low band is still wide though (I didn't see whether or not the Syntors he has are low or high).
whirley1
wichita, ks
vehicle repeater
who can tell me how a uhf ht that goes thru a vehicle repeater and comes out on the mobile vhf channel. How does the repeater know what channel to use? and to all you couch fcc police, No I am not licensed.
Citywide173
Attleboro, MA
The radio doesn't "know" anything. All parameters have to be entered by the operator, then the cross band function has to be activated. This is the common amateur radio version. Commercial crossband "repeaters" are two radios tied together with all of the parameters programmed by a radio shop and not accessible to the operator in most cases. There may or may not be an activation switch in this case.
EDIT
I'll try my hand at a diagram. This would be a full power VHF mobile and a UHF mobile repeater.
VHF TX <---> UHF RX Signal received at the repeater from UHF portable is interfaced to the transmit side of the VHF mobile and sent to dispatcher
VHF RX <---> UHF TX Signal from dispatcher is received on VHF mobile and interfaced to the transmit side of the repeater and sent to the UHF portable
RFI-EMI-GUY
You might check the Pyramid Communications site and download some manuals from the support webpage for better understanding.
I will use example of UHF portable, UHF vehicular repeater (VRS) and VHF mobile radio:
Speaking of the UHF link from the portable radio to the mobile vehicular repeater (VRS) equipment, most vehicular repeaters are single channel though Pyramid sells a multichannel that is manually set.
The UHF portable transmits a CTCSS tone to the VRS equipment and does not require a CTCSS tone on the return link from the VRS equipment. This is so two or more nearby VRS's don't try to repeat each others traffic and feedback.
Normally the VRS retransmits to/from whatever VHF channel the mobile radio in the vehicle is selected to. It is possible to configure a multi-tone CTCSS decoder in the VRS to select different VHF channels of the mobile radio. This is called channel steering. This means the operator selects a mode on the UHF portable that sends a different CTCSS tone for each VHF channel desired, (Dispatch, Car-Car, Records, etc). Another lesser used option is to use a DTMF command from the portable to remotely select the VHF channel.
In nearly all cases, the VRS is single channel and channel steering of the mobile is not used. Some sophisticated agencies such as CHP use channel steering and other advanced features because they almost entirely use the VRS systems to communicate.
The VRS system also has a tone which is sent to engage a priority timer to prevent two or more VRS's used nearby each other from transmitting over each other. The tone is transmitted whenever the VRS is engaged by the operator. This can be as simple as a switch on the dashboard or some logic sensing the vehicle is in the park mode and the seat belt is disengaged indicating the operator is away from the vehicle. The Pyramid manuals describe this mode. If you can find a old copy of the Motorola Pac-RT manual, the operational theory is described in great detail.
mikewazowski
Staff member
Forums Manager
Oot and Aboot
Threads merged and left in the Industry Discussion forum.
whirley1
wichita, ks
thanks everyone for your help. Now that I am thoroughly confused, can I get a real simple answer as to what type of antenna do I put on my vehicle. uhf or vhf thanks again,
whirley1
wichita, ks
now that I'm throughly confused, what type of antenna do I mount on my vehicle. uhf or vhf. my repeater only has one antenna connector.
RFI-EMI-GUY
Now that my response has been merged with your original post, I surmise that you have purchased a bunch of Motorola gear that was surplus-ed by some agency and you are seeking to put it into use for business (FCC CFR47 Part 90). Other posters have mentioned correctly that the equipment you have is no longer suitable for Part 90 operations since the FCC completed the mandatory transition to 12.5 KHz narrow banding in 2013. This equipment is still suitable for Ham radio (Part 97) and the UHF equipment may be type accepted for UHF GMRS (Part 95). As you are probably aware business radio operations cannot take place in Part 97 or Part 95 bands. The only exception is for a family business, GMRS is allowed, provided non family members do not utilize the radio system.
I suggest that you contact a friendly local commercial two-way dealer who can advise you what current radio models may be suitable for your application. The equipment you already have, you might wish to resell to buyers who may have better use.
You are welcome to contact me if you have further questions. I am a consultant, not a dealer.
cmdrwill
So Cali
sorry, the mobile is a syntor vhf high band 150-174 32 channel
Syntor VHF is not currently type accepted on any services, part 90 or 95. Not even good for two meters Ham without lots of modifications.
Shifty thinking
Usually on the older Moto's, you can hold down the shift key to enter out of band freqs.
I've never programmed a Syntor.
Will that work for a Syntor?
SteveC0625
Order of the Golden Dino since 1972
Northville, NY (Fulton County)
Unlike more modern radios, you didn't just plug in a cable and fire up a CPS on your computer to do this. Programming a Syntor required a PROM burner. The EPROM has to be removed from the radio in many cases, and placed in a special fixture to be read and then written back to.
There are still some folks that have this capablitiy, but it's fading fast. Those interested in Syntor's will find a host of information here: Motorola Syntor, Syntor X, Syntor X9000, MCX and Mostar Information Index
FWIW, I had a 100 watt Syntor in an ambulance some 20+ years ago. It was one kick-*** radio at the time.
R8000
Very Low Battery
This is the best advice yet, and I was going to say the same thing. It sounds like you are in way over your head and trying to make this work is only going to get you in legal trouble.
If you are running a security business, you don't want to have the embarrassment of being fined for putting these on the air and end up jamming a local user who happens to be on the same channels PASP used.
hamptonbeach
Field of Dreams
I know this thread is a little old, but I know exactly what this guy has because I have several of them myself. The were surplused from PA State Police. It is a VHF Syntor X9000 with a box that mounts under the drawer unit. Inside this box is the Y1082A. It has 2 antenna connectors, one labeled radio and the other antenna. There is a data connector that piggybacks on the drawer unit main block.
Inside it is a VHF crystal controlled receiver (YLD1003A) that looks part Mitrek. It has a HLD4052A pre-amp. There is a Motorola RDD4684A six can duplexer, and 2 antenna relays.
Think of the old Flexar repeater and you will grasp the concept.
In normal operation of the mobile unit, the RF relays would by-pass the Y1082A.
There is a repeater button on the Syntor control head that I imagine would energize the RF relays inside the Y1082A so a received signal would get routed to the external receiver.
The frequency the PASP used was 154.755 simplex. A handheld would transmit on 159.21 (PL 186.2) and the Syntor would repeat it on 154.755. The handheld would receive replies on 154.755.
Everyone is correct here that the Syntor itself is useless for commercial operation anymore, and the 150-174 split doesn't tune well to ham IIRC, and you have the hack the RSS to program the frequencies out of band.
Here is someone selling or inquiring about the same thing (pictures)
สà¸*บถามà¸*ุปà¸à¸£à¸“์ Motorola Model:Y1082A
Personally I'm interested in any information on the duplexers - anyone?
Project25_MASTR
TX-COMU
Texas
Odd little side note. Came home with 11 RNet 450's today…several pieces of literature have not only referenced the RNet 150/450 as the VRS radios…but also nearly identical to the EXPO HT's on the main TX/RX board.
