clyde
Radio service testing Ch 1 yesterday. New pl?? Not hering much today.
kb1hwh-2 said:Vernon's 460.325 is now PL 91.5.
slammed said:What does PL 91.5 mean sorry noob here
Southtown800 said:why does it matter if they change the PL if they are keeping the same frequency?
slammed said:Hey I did here animal control today I am not sure what channel because I just put a bunch in I dont really know whats what yet
I was hoping to find I good list on the forum but not yet
PJH said:Usually its due to interfearence issues. Either within town or way out of town. Its not a hard thing to do, just a royal PITA. PL's are not changed just because your bored of the PL tone.
y10kiscoming said:I assume you've got all the ones in the database? I've posted everything I have heard myself. What other frequencies were you looking for?
Tolland DB: http://www.radioreference.com/modules.php?name=RR&ctid=310
-Mark
clyde said:Y10Kiscoming what equipment are you using to decode the MDC1200 codes? Am interested in doing this myself.
slammed said:Yes I read and added some of those howeverwhat is the difference between the colums frequency and input? or I should say which one do I use? I have a pro 2020
y10kiscoming said:This deals with the way repeater systems work.
Again, the Wiki is a newbie's best friend:
http://www.radioreference.com/wiki/index.php/Repeater
Basically the Input is what the radio transmits on, and the repeater "repeats" it on the output frequency. You will want to be listening to the output frequency, which is the lower one. In the 450-470mhz range, output and input are separated by 5Mhz. So Vernon output is 460.325 and input is 465.325. Listening to the Input is fun only if you want to see if any cars are relatively close to you.
-Mark
vs1988 said:What are POST IDs?
Vince
y10kiscoming said:POST ID is an MDC1200 data burst at the *end* of a transmission. It sounds like a "chirp". It basically contains some numbers which include the unit's identification number.
-Mark
vs1988 said:Thanks. Also, what is MDC1200 data? My local PD has the "chirps" at the end of their mobile/portable transmissions, but base doesn't have it.
Vince
