Vernon PD
vs1988
Thanks again! Have another question: Are these data bursts also used for MDTs? I occasionally hear a chirp that sounds like someone keying up quickly and letting go. I'm wondering if this is a keyup or a data packet being sent.
Vince
PJH
MDC is "Motorola Digital Communications - A Motorola-proprietary signaling format. It is a binary format using a 1200-baud Minimum Shift Keying modulation. MDC-1200 is used for IDs, Selective Signaling, Emergency, Status/Message and Text."
There is MDC-600 and MDC-1200. MDC-600 was the first true digital signaling format out back in the late 70's and I believed introduced in the Syntor/MX series radios. MDC-1200 is the most widely used and has pretty much been a stanard feature since the Saber/Spectra series radios were introduced.
MDC-4800 and a couple of other varients exists, but its mostly paging and other data networks and not with two-way radio as being discussed here.
To the human ear, you cannot tell what is being sent. Even the sequnence is the same over various commands. For instance, "Emergency (man down)" and "Call" features send out data packets at the same interval, however "Call" will wait if there is traffic on the channel. Emegerency can overide this feature. Same with the page, status, message etc.
Depending on the radio and model, you can have the ID sent prior to speaking, after speaking or both. Not all radios support the above. ID's are 0001-FFFF or 0001-FFFE (0-9/A-F) and are transmitted in Hexidecimal format. If you see a radio or dispatch console display a name, this is called an Alias and is preprogrammed into the radio. The radio itself only knows Hex and transmits that data.
MDC-1200 is not used for MDT operations. They are on a private switch thru Verizon or Sprints cell network in Connecticut. I know there was a big swtich from CDPD to a faster data network. I am pretty sure Verizon was retained for the data network. CSP operates its own data network thru its trunked system.
y10kiscoming
Groton, CT
Vince
I would have to guess no on that one. It probably *is* just someone keying up.
I'm pretty sure Vernon uses the CAPTAIN Mobile Data Communication System
More info here: http://www.crcog.org/public_safety.htm
As of yet, I have no information as to what frequency/ies or data format it is using.
-Mark
PJH
The CAPTAIN/Bluelink system runs off of the commerical cell system just like an internet data card does. The switch is/was located in Hartford of East Hartford. Its just a large VPN connection back to the state using Sierra Wireless modems. Because of the switchover, some departments are also using air cards for laptops, PDA's etc since it was something that wasn't available in the CDPD era.
y10kiscoming
Groton, CT
Thanks for the info.
Do you know *everything*? LOL :)
-Mark
P.S. Love the avatar.
PJH
Lets just say I have an very inside position on things. :)
