Vertex 354 Error
wdugan
Ewing, KY
I am trying to program a vertex 354 with CE 86 but every time it goes to upload I get an Hardware Type mismatch error does anyone know what could be causing this
MBill
First I would do a search on the VX-354 in this forum. Similar issues covered with some
suggestions.
Check your config file setting for the com port in the Vertex menu. Could be port issue.
Possible radio is bad too or maybe programming cable not correct one or defective.
Someone in the forum probably has the answer
VSTech
Borden, IN
Mismatch Error can be caused by the three of the following:
1. Wrong Firmware
VX-354-AG?? or AD0B models should only have FW 1.25
Where as VX-354-G? or D0 models should have FW 2.04
2. Placing CE86 in manufacturer mode and cross loading the two models. Manufacturer mode can also fix this issue sometimes !!!
3. EEPROM defective
VSTech
Borden, IN
Does the serial number fall between 6Hxxxxxx and 9Hxxxxxx (8 digit)? If yes and you haven't sent it in for the free ceramic filter update (TB201206-4) do so. Free CF1001/1002, Firmware Update, and Realignment.
BUT, please tell Vertex "TB Only", if not you'll be charged flat rate.
wdugan
Ewing, KY
I finally got it it was software wrong version upgraded to newer version and work great Thanks for the help
